Old 01-03-2008, 05:19 AM   #131
SwissArmySuv's Avatar
Member Number: 1693
Re: Overhead map light install (lots of pics and details)
The GM light pretty much goes straight on-off. What some people had done was add an additional small on-off switch to the GM light to be able to control it when the door was opened.
SwissArmySuv is offline
Old 01-03-2008, 10:15 PM   #132
Member Number: 16748
I came to the party late... Is there any way to get a bracket? 1st gen or 2nd - either is good for me. I don't have metalworking tools or I'd just fab one myself - your directions were quite clear IMHO.
Thanks!
ImagoX is offline
Old 01-04-2008, 07:04 AM   #133
Steve_53's Avatar
Member Number: 9264
ImagoX previously said: View Post
Thanks!
PM sent.
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
Old 01-04-2008, 09:44 AM   #134
You da man - thanks!!
ImagoX is offline
Old 01-11-2008, 01:50 PM   #135
Member Number: 16020
e-mail me if you want a detail drawing of the mounting bracket
gumby99 is offline
Old 01-12-2008, 01:32 PM   #136
Singha's Avatar
Member Number: 12233
I am ready to do the mod also. Gather up everything except the bracket.
Would you have one more bracket? If not a drawing will do.
lookin for a used rear Warn bumper.
TLCA#18914
GCLC#2083
Bone Stock Fj-C, but looking to mod it up soon.
Singha is offline
Old 01-12-2008, 09:27 PM   #137
jkjet's Avatar
Member Number: 11977
I finally got my overhead mod installed and here it is
I went with the 2004 Honda Odessy set up with Homelink. I decided to put it in this position because it looked closest to stock close to the mirror. I connected the lights and ran it fore and aft and really didn't notice much change in the shadowing. It does a nice job illuminating the ignition and cup holder, I am very happy with the increased light. It also lights up the upper glove box. I primarily installed this unit to get the Homelink, which works great. I had to fab a bracket off of the mirror. It fits very nice, only gapping slightly on the sides. The color match is almost perfect, gray according to the person I purchased it from on Ebay. Special thanks to Singha for providing the connector and wesayso and Swiss for the original idea and help.
The lights fade in and out just like stock. Here it is lit up.
Thanks Again, This Forum Rocks!
jkjet is offline
Old 01-12-2008, 09:30 PM   #138
Singha's Avatar
jkjet
Looks nice, I have the same one.
Would you have an extra braket? I need one for my install.
TLCA#18914
GCLC#2083
Singha is offline
Old 01-13-2008, 05:31 AM   #139
jkjet's Avatar
Singha previously said: View Post
I only made the bracket out of some household duct sheet metal I had laying around. It is pretty flimsy stuff, so I intended on using it as a template. After I finished, it was so secure I decided to go with it. The Bracket just covers the light section and the clips by the sunglass holder takes care of the rest. I just traced out the front and added a wide tab down and under the mirror. I also bent in a tab on either side to help push the ceiling down to the overhead. I still got a small gap, maybe 1/16", which would probably go away if I used stiffer metal. I also to cut out holes for the backs of those bulbs and the plug. I neglected to snap a picture prior to install. When I get a chance I'll try to drop the unit and get a shot.
jkjet is offline
Old 01-13-2008, 04:48 PM   #140
jkjet's Avatar
I dropped the overhead and was able to get a few good shots of the bracket. It looks a bit crude, but it makes the unit nice and secure. I was able to almost eliminate the side gap by bending down on my side tabs some more. I also added foam tape to the top of the glasses part to firm it up.
The front end goes under the mirror:
Here is the end with the bends to push the headliner into place:
Here is the screws I used: I think a short #8 sheet metal
Make a template out of cardboard and fit it to the console. Once your happy with the fit , transfer it to the headliner and cut away. I made mine pretty snug. Good Luck.
jkjet is offline
