Old 01-26-2008, 02:54 PM   #141
Member Number: 15914
Re: Overhead map light install (lots of pics and details)
Ok, I have a few questions concerning the wiring.
I am installing a Garmin and want to mount it above the rearview mirror. I would like to tie the unit wiring right into the door lamp. Are any of the wiring for the door lamp accessory power on when key turned on? Which ones? Thanks
Hyperjoe is offline
Old 01-26-2008, 03:31 PM   #142
jkjet's Avatar
Member Number: 11977
Hyperjoe previously said: View Post
There are three lines that come from the dome light. One is the ground, one is hot all the time, and the last is powered on all the time until you open the door then it goes of for 30 sec. this is the control circuit for the door open light mode. If I was to add a GPS up there I would grab the power from in the drivers A pillar. There is a connector there with a red line that is powered all the time, there may also be a line, that is powered through the acc. I'd have to check the wiring diagram or test it to know for sure.
jkjet is offline
Old 01-27-2008, 09:37 AM   #143
SwissArmySuv's Avatar
Member Number: 1693
jkjet previously said: View Post
you are correct .. you could tap here (a-pillar):
however, another thought would be to continue the tap line down thru the dash, installing the correct amperage inline fuse (my GPS is 3 amps), and then connect into the fuse block.
by tapping into the a-pillar, you either use whatever fuse amperage is on that circuit (which could be too high for the GPS) or you add a fuse there which would be inconvienient.
SwissArmySuv is offline
Old 02-28-2008, 06:21 PM   #144
Tarik's Avatar
Member Number: 7229
Anyone in SoCal want to help out a fellow FJ owner?
Hey guys - Installer request here.
I just ordered the Acura console (looks identical to the Honda one above). It should be here in a few days.
I'm in Venice, CA - would anyone local be up for helping me out? I pay in whatever currency make you happiest ($, beer, pizza, ). I'm ok with the cutting, etc. Just need help with the wiring and braket if needed to secure the unit.
Tarik is offline
Old 02-29-2008, 07:04 PM   #145
jkjet's Avatar
Re: Anyone in SoCal want to help out a fellow FJ owner?
Tarik previously said: View Post
Sorry, I'm on the wrong coast. It's really not too hard to do, if you have some basic mechanical skills. Use a sharp blade if you decide to cut the headliner yourself.
jkjet is offline
Old 02-29-2008, 07:26 PM   #146
Skoaltrain's Avatar
Member Number: 17993
Great job!
I like it alot!
Skoaltrain is offline
Old 12-18-2008, 04:34 PM   #147
DethJ9000's Avatar
Member Number: 24445
Thumbs up Re: Overhead map light install (lots of pics and details)
It's definitely looking nice. What I'm wondering is if you can find some low-level LED's for tactical reasons...
Now that would be extra special. The job is beautiful man, what more can I say!
"Attack life. It will kill you in the end."
-T. Ward
http://myspace.com/donkeystylee
DethJ9000 is offline
Old 12-18-2008, 05:53 PM   #148
danieloz46's Avatar
Member Number: 19957
Good taste! Same one I installed a while back. I managed to hit the crossbeam, no bracket needed. Love it. Good job.
dan
2008 Titanium 4x4
Convenience package & Upgrade package #2, alloys.
Mods so far: Added roof rack, passenger armrest and spare tire cover. Underdash lights. LED Puck lights to backseat interior. Dual horn install. Installed LED's to center dash panel & cupholder. Map and front dome lights.
danieloz46 is offline
