Going to do 1 more post and then let it rest ...
A number of people sounded like they are going to try this also, way to go!
You will like the results. Also, a number of you buying your lights, might
think .... I wonder if that guy will follow through with my bracket?
Well, here's the answer ... bracket making 102.
did the prelim layouts (forgot to take a picture, I had already drilled some)
drilled some holes
scored the cutoff line about 1/3 matl thickness then broke it off
cleaned up the edges
put the bracket in a vise and squared it up
came up with a "forming tool" since I don't have a press break at the house
bent the sucker over
added a 15 degree overbend to the front flange (note the high dollar gauge)
2 episodes of american chopper later ....
12 completed brackets
Hope you all enjoyed my little project, I had fun sharing it with you.
