wiring thru the firewall - Toyota FJ Cruiser Forum
post #1 of 22 (permalink) Old 11-21-2012, 10:39 AM Thread Starter
Quoted: 2 Post(s)
hey guys i want to install a radar system in my truck can you guys help me with some links or pictures of how to get a clean ( none warrenty void ) thru the firewall system ...
i have a 2011 FJ cruiser
thanks
w8tng4nepiphany is offline
post #2 of 22 (permalink) Old 11-21-2012, 10:44 AM
hikeswithdogs's Avatar
Quoted: 7 Post(s)
Re: wiring thru the firewall
w8tng4nepiphany previously said: View Post
thanks
Black Rubber graumet on the back right hand side of the engine compartment.
http://www.starmanage.com/starmanage...l/IMG_4883.jpg
hikeswithdogs is offline
post #3 of 22 (permalink) Old 11-21-2012, 10:46 AM Thread Starter
Quoted: 2 Post(s)
hikeswithdogs previously said: View Post
thats standing in front of it correct ? is it easy to pass wires thru will i run into any problems ????
post #4 of 22 (permalink) Old 11-21-2012, 10:49 AM
Dennx's Avatar
Quoted: 84 Post(s)
I'm not sure if it voids the warranty, but here are two ways I did it or a rubber boot you can use for varying number of wires. Yes, it's on the driver's side where the main wire loom enters the FJ. You can see a portion of it in the photo below on the bottom edge. It's easy to pass wires, you just have to cut the firewall insulation. I cut it first, then drilled. I only cut 3 sides of it to create a flap so it's still attached.
The smaller cable gland uses an exisiting hole I enlarged and the larger cable gland is a new hole I drilled, both with a step down bit.
http://www.amazon.com/Daystar-KU20040BK-Black-Universal-Firewall/dp/B004K2285E
My Photos - My Build - K6DNX
Managing Editor, TCT Magazine
Dennx is offline
post #5 of 22 (permalink) Old 11-21-2012, 10:49 AM
Quoted: 7 Post(s)
Yes sir, I'll try and find a better picture.
I needed the girlfriends help to push through a 4 gauge cable for stereo\amps and it only took us about 10 minutes but something flimsy\limp like a skinny cord may be more of a challenge.
good luck
post #6 of 22 (permalink) Old 11-21-2012, 10:51 AM
Quoted: 7 Post(s)
Here's a better pic of the firewall hole
http://www.starmanage.com/starmanage...l/IMG_4885.jpg
Instead of just flat out removing the black rubber graumet drill\cut a small hole in it so you can run the cable through it and put the gramuet back in if you can.
post #7 of 22 (permalink) Old 11-21-2012, 10:58 AM Thread Starter
Quoted: 2 Post(s)
thanks ill look this weekend see what i can do .....
post #8 of 22 (permalink) Old 11-21-2012, 11:58 AM
tormented's Avatar
Quoted: 1 Post(s)
If you have cheap a wire puller or a long screwdriver or something like that you can push it through from the inside, tape the wire to the puller and give it a lil tug. I have 1/0 awg, 2x 8 awg and a bunch of smaller wires running through that grommet. You should have no problem.
Then if you pull out the glovebox over the steerin wheel you can easily route the wire up and over the steering wheel or to where ever you are mounting it.
Sent from my iPhone using AutoGuide.com App
tormented is offline
post #9 of 22 (permalink) Old 11-21-2012, 12:49 PM
MattM's Avatar
Quoted: 64 Post(s)
Send a message via AIM to MattM Send a message via Skype™ to MattM
For my amp power, I just poked a hole in the existing rubber grommet on the driver's side, adjacent to the existing cables. Then pushed the cable through and sealed with a bit of silicone.
- Matt
MattM is offline
post #10 of 22 (permalink) Old 11-21-2012, 01:25 PM Thread Starter
Quoted: 2 Post(s)
MattM previously said: View Post
if you get a chance this weekend can you take a picture of the area of how you ran the wire ?
thanks
Human Verification
