Up here in the pacific northwest, some wheelers will tell you chainsaws are a great idea to have, especially in the spring when you often find the previous fall/winter storms have knocked down trees across the roadway. Guys are guys, and if someone could fit a 4-cyl 22R on an 18" bar and pick it up they'd do it.
However, space and weight being at a premium, I am all about efficiency. I've been thinking about spending < $100 on an electric chainsaw, and just running it with a 100' extension onto a decent AC converter. For instance, there's a $69 Yardworks unit with 16" bar and 12A motor with a 2 year warranty. And you don't have to worry about packing a device with gasoline inside your vehicle. In addition to considerably lighter weight, easy starting, easier storing (can be hung upside down or vertically with no issues), virtually maintenance free, given I have an electrical system upgraded to handle it, is there really any disadvantage to using one? (Aside from snickers from your mates when you pull it out of the back.)
Part 2 of my question is electrical... what would an electric chainsaw pull and would the electrical upgrade requirements be so costly that a gasoline powered saw makes more sense economically?
_______________ Pete's current setup: 2010 Sandstorm :: auto :: UNbroken windshield :: 285/75R16 BFG Mud Terrain KM2s :: All-pro skid plates :: Walker Evans Racing coil overs & shocks :: Bulldog winch :: Demello bumper & sliders :: snorkel :: rock cams w/7" LCD :: Asus TF201 Prime nav :: Intronics dashcam :: Scangauge II :: Uniden PC78 :: 10# Powertank CO2 :: dual Viair 150psi onboard air :: DP Dual Battery kit :: Rigid E-Series 20" + 2x10" :: s-POD :: Onboard LTE Wifi On order/ready for install: Vision X rock lighting :: Grover stutter horn (yeah, still) Expeditions: Summit 2012 :: Cruise Moab 2013 :: Summit 2013 :: Beaufort Sea 2014 :: moon 2065
TLCA#22101
120volts x 12amps = 1,440 watts. So you'd need an inverter strong enough to put that out continuously. Definitely upsize and get a thick extension cord if you're gonna go 100ft to compensate for voltage drop.
I would agree and back you up that it would be much cleaner/safer/practical to carry an electric version. So long as it has the guts to do the job.
2007 VooDoo 4x4 Auto - LOADED
OEM Roof Rack, Rock Rails, TRD Exhaust
Ricochet bash plate
Manik brush guard w/ Blitz 240s
Add'l 12v outlets, Scuba Mod, Amaesing hood decal.
08-09 side sun visors
265 Revo 2's on flat black steelies. Bilstein 5100's to level the front. Backup Camera w/ 7" monitor Power rear window mod Hemi71cuda's Build
i borrowed an electric chainsaw from a friend just to cut some small limbs, not with the fj inverter, and it worked for a little bit and then caught on fire, i guess it was from sawdust that got in the motor. and unless you pay good money the gas engines have been not so good either lately . i would go quality gas if you use it enough, otherwise let us know what you choose and how it works.
I have a 16" Mac that I take camping. I usually have to walk off the trail way more than 100' to cut up that nice dead tree that's ready to burn. If you like to camp and you like plenty of firewood an electric chainsaw is simply out of the question.
Forty Years of FJs
*1967 FJ40 Rock Crawler & 2007 FJ Voodoo Blue*
OME 3"Lift - Light Racing UCA - DeMello Bumper - 12,000# Winch - Warn Rear Bumper - MagnaFlow - Cobra CB / Bandi Mt - A-Track, Diff Lock, VSC, & Door Chime Hacks - 285-70-17 Bridgestones - 2 Horns / Wolo Bad Boy - Chrome Tube Front Grill - Ellis Shift Knobs & Batt clamp - Sylvania Silver Stars - Clazzio Leather - Blue Sea Fuse Panel - Die Hard Battery - Kenwood DNX6980 Nav Radio - Oznium LED Dome Lights - Prodigy Controller -SCUBA - Tinted Windows - Springtail Rear Door / Side Rack Combo - Tru Cool 4454 Cooler - VIAIR onboard Sys -All-Pro Sliders
Big fan of electric chainsaws and their dependability. They are also relatively quiet which is a big plus in some situations. You still have to carry bar lube though.......
A good quality bat op sawzall with an agressive 12" wood blade can be equally effective while being self contained.
