Old 01-28-2007, 11:09 PM   #1 (permalink)
Air2air's Avatar
Member Number: 6928
Air2air's FJ computer mount - step by step
This is my 2.0 FJ computer mount for tablet PC's. It can fit your laptop with some tweaking. With a cellular aircard for about $50-60 a month, and a USB GPS and topo software for about $200, you get a whole nav PC for just a few hundred more than a standalone GPS.
Pros:
  • Passenger-safe. The unit is not in the deployment path of the airbags on the dash and A-pillar.
  • Car-safe. Does not put a mark on the car.
  • Knee-safe. The keyboard/mouse tray folds up to partially obscure the computer.
  • Extremely solid and will not move.
  • 18ga. steel construction. Aluminum is optional.
Cons:
  • Will require adaptation to mount your specific laptop.
  • Complicated. Have it built by your local metal fabrication shop if you don't have the following:
    1. Riveter or welder - gas, mig or tig
    2. Sheet metal bender; slip roll optional
    3. Angle grinder
    4. Cobalt drill bits
    5. Sheet metal shears
With the tools above, it should take a day to build and a day to fit and finish.
I'm putting this into two posts; the second following is a step-by-step of the build process:
Air2air is offline
Old 01-28-2007, 11:10 PM   #2 (permalink)
Air2air's Avatar
Member Number: 6928
Re: Air2air's FJ computer mount - step by step
OK here's how to do it. You will need a few feet of 3/8" tube and about 8 sq.ft of your chosen sheet material, either aluminum or steel. And several feet of the big 2" velcro.
The backplate creates a foundation to mount the brackets and keyboard shelf to. It hugs the contour of the dash including the radius at the top. It follows that radius all the way over to where it ends at the top, to form a big clip that the entire assembly hangs from. Later the backplate will be very securely velcroed to the dash from locations on the back and on the radiused portion.
Note the two "ears" at the ends for the keyboard shelf. These can either be welded on or bent as I have done. The only reason this assembly is in two pieces is that it was a prototype - you can do this out of one piece.
These are two vertical brackets that push the computer out away from the dash about 1.25". This is to get the back of the computer out flush with the dash's top and bottom radiuses to accomodate a taller screen. The holes are drilled for my computer only - not yours.
The brackets are welded 12" apart. For your laptop, you might attach a piece of masonite between the two brackets and attach the back of your laptop to that.
My tablet PC came with this plastic holder that was pretty ideal. I drilled the previous bracket holes to mount this holder.
These arms will bolt to the "ears" on the backplate, and hold the keyboard shelf. I pressed 3/4" of the ends in a vise and then drilled them. Then, round off the ends with the grinder.
For me it's a keyboard/mouse shelf but for laptop users it holds up the bottom of the laptop. You have 19" of allowable width until you start to interfere with the right door handle, and the support tabs are 14" apart. Otherwise, all other dimensions are up to you. I can see wanting to do something deeper to support the front of the laptop, for instance.
The 3/8" tubing I reinforced with is optional. You can use other sections like a 1/8 X 1/2 bar, for instance. This would be easier to bend of course. The support tabs are scrap 1/8 X 3/4 bar, but use whatever you have.
The arms are bolted tightly in place to the ears on the backing plate. Note that they point down at a 30 deg. angle so that the passenger does not become a shishkabob. The specific angle is up to your needs.
The shelf is bolted to the arms and we're almost home. I used locknuts so that the shelf can be flipped up as you see at right.
And at 1:00am we are ready to dry fit. Forgot to take a picture of the velcro, but you are running 3 of the 2" strips, cut to 14". The first goes across the very end of the curved radius at the top. The next two go across the vertical portion of the dash. Make the velcro the last step after painting, computer installation, etc. because with that amount of velcro, the mount just ain't coming off without a major fight.
Finishing notes - I also forgot to photograph the two trim pieces that you see on either side of the screen. These are both 6" high. The left one is 3" wide and the right is 6". The right also is radiused to match the dash. These two pieces are highly optional because, again, they are specific to my mount.
The blue stuff? That's neoprene from Michael's. Yeah, the big craft supply place. They have really cool materials... I am gonna do a full-length mousepad across the keyboard for instance.
Good luck folks!
Air2air is offline
Old 01-28-2007, 11:11 PM   #3 (permalink)
Noisycow's Avatar
Member Number: 3046
Fantastic - you are one talented SOB.
Noisycow is offline
Old 01-28-2007, 11:13 PM   #4 (permalink)
Member Number: 8457
Send a message via AIM to Dmitry
who is doing your photo work for you?
Dmitry is offline
Old 01-28-2007, 11:15 PM   #5 (permalink)
frogeye's Avatar
Member Number: 6849
Exclamation Re: Air2air's FJ computer mount - step by step
Noisycow previously said: View Post
Damnit mang! Look at that sweet arse setup now. Awesome job.
That thing blows my passenger shishkabob device away! I like how you painted it voodoo blue to match your rig.
Chris
frogeye is offline
Old 01-28-2007, 11:19 PM   #6 (permalink)
Air2air's Avatar
Member Number: 6928
I forgot to mention that Frogeye has a simple and easy to build version as well, weeks before mine.
To show your thanks please PM him some hot photos of your woman.
Air2air is offline
Old 01-28-2007, 11:19 PM   #7 (permalink)
Prof T's Avatar
Member Number: 6710
Well, I must say the best. Thanks for the details. Want to sell one?
Prof T is offline
Old 01-28-2007, 11:30 PM   #8 (permalink)
Air2air's Avatar
Member Number: 6928
Hey Prof T - thx for the rep by the way!
If I had to make one of these again it would have to be under too much inebriation to work at all.
Also for the amount I would have to charge, you would look close up at the finish quality and come after me with the lawyers.
Air2air is offline
Old 01-28-2007, 11:30 PM   #9 (permalink)
Terahex's Avatar
Member Number: 1680
Location: HELL ...................... if I don't change my ways :)
You bastard! That is just totally awsome! I am so envious!
2007 Toyota FJ Cruiser MT6 VooDoo Blue (FE, CQ, GY, RB, UR, CF, C7, V5)
Mods: Kenwood DNX7100 | Expedition One Sliders | OME Medium Lift | Original Bandi Mount | CB | 285 Nitto TerraGrappler | HiJack Roof Mounts | ScanGageII | Rear Door Storage Net | TireCover Mod | PIAA Headlights | Passenger Armrest | VooDoo Tent Trailer
WishList: Skid Plates | Wet Okole
Member: NorthWest FJ Cruiser Club
Terahex is offline
Old 01-28-2007, 11:33 PM   #10 (permalink)
Chatsworth 818 FJ's Avatar
Member Number: 1770
Holy chihuahua spit, nice work!!!
when I saw the raw pieces, I had to scroll back up because I couldn't even see them in the finished product, the top round piece looks part of the FJ, very very nice work, you need to make some for sale, Im sure you would sell alot. Id trade U for one for a nice set of new cobalt drill bits I got from my work I sell.
Chatsworth 818 FJ is offline
