Roof mounted CB install - Toyota FJ Cruiser Forum
post #1 of 25 (permalink) Old 02-17-2007, 10:00 AM Thread Starter
Regreb's Avatar
Quoted: 0 Post(s)
Send a message via Yahoo to Regreb
I haven't see this done on this forum yet so I figured I'd give it a shot. I thought that it would be about the best place for the FJ. Others asked if there was anything to mount to and no one could answer or knew for sure. Well the answer is nothing to mount to. I pulled the head liner down and saw the roof sheet metal where I wanted to mount it. I didn't think to take any pictures of the job wile I was doing it, probably because I was so excited to get it done. I thought of a few different ways to make a mount involving some sheet metal and some tack welding but was worried about messing the paint up on the roof. Then thought about bonding a bracket up there. Wile I was trying to figure the spacing from the roof to the head liner, I found that a piece of 2x4 was perfect. So instead of making something I figured I just bond the 2x4 up there and screw the CB mount to it. Works like a champ so far. I've used Gorilla Glue in the past on some funky materials like stone and uneven plastics and it holds very well. It foams and expands as it dries. I cut a piece of 1x to wedge between the center console and the 2x4 that was being bonded. I left it that way over night but the directions say 3-4 hours. I also found that a trunk mount works perfect for the antenna. I used a Wilson 1000 for the job. I've used these antennas on many vehicles, and they perform wonderful. Your CB is only as good as your antenna.
Regreb is offline
post #2 of 25 (permalink) Old 02-17-2007, 10:22 AM
gsgmac's Avatar
Quoted: 1 Post(s)
Re: Roof mounted CB install
So, how big of a gap is there between the headliner and the roof....you said a 2x4 was used, so does that mean the gap is 2"?
Thanks in advance.
gsgmac is offline
post #3 of 25 (permalink) Old 02-17-2007, 10:33 AM Thread Starter
Regreb's Avatar
Quoted: 0 Post(s)
1.5 inches. The headliner flex makes it forgiving if your a little off. 2x4s are typically 1.5 inches. I wouldn't make it any thicker or it might bulge some.
Regreb is offline
post #4 of 25 (permalink) Old 02-17-2007, 10:45 AM
Putts255's Avatar
Quoted: 0 Post(s)
Send a message via MSN to Putts255
Nice post. I like the trunk mount idea for the antennae too. I yanked my old CB out of the Van before it was sold so will have to find a place and a new antenna. Gives me more fuel to do some more stuff come spring time.
Thanks for the post.
Black Diamond, 6MT, Full Load
Stock except hitch and harness
Black Ellis Battery Clamp
Custom LED Overhead light
Wet Okole Seat Covers....
LED Accent Lights
Scan Gauge II
Putts255 is offline
post #5 of 25 (permalink) Old 02-17-2007, 11:01 AM
Quoted: 1 Post(s)
Nice job. Great installation. Did the antenna cable run from the back door to the front through the head liner, or is it round about and up the A pillar?
We're now a two FJ family
Black Diamond and Black Cherry
bncsauve is offline
post #6 of 25 (permalink) Old 02-17-2007, 11:05 AM
gsgmac's Avatar
Quoted: 1 Post(s)
Regreb previously said: View Post
Cool, I was thinking of using the headliner center console out of the new Tundra....it looks like it might work, I just need to get my hands on one and check out the mounting. It has a couple of pockets and the all important map lights. BTW, I mounted my CB the the back of the center console between the front seats...it was thin enough to not interfere with the rear seats when folded down. I like your mounting location though, very nice!
gsgmac is offline
post #7 of 25 (permalink) Old 02-17-2007, 11:40 AM
Spike Strip's Avatar
Quoted: 0 Post(s)
Nice job... Gives me a few ideas
Spike Strip is offline
post #8 of 25 (permalink) Old 02-18-2007, 02:22 PM Thread Starter
Regreb's Avatar
Quoted: 0 Post(s)
bncsauve previously said: View Post
The cable had to go through the head liner. The antenna came with 18 foot of cable and there wasn't enough to go under the door sill and back up the A-pillllar. There was only a few inches of cable to spare with it above the head liner. I think it was a little easer that way since I had to take the head liner loose anyway.
Regreb is offline
post #9 of 25 (permalink) Old 02-18-2007, 02:32 PM
Strike's Avatar
Quoted: 0 Post(s)
Nice install. How do you remove the headliner?
Strike is offline
post #10 of 25 (permalink) Old 02-18-2007, 02:45 PM
Quoted: 0 Post(s)
HI,
Very nice job on the install, I like being able to see the unit, and controlls. Just a question about the 1" x 1" spacer, I don't get where it sits exactly, and what it is doing. Is it tilting the 2x4? or did you take it out after using it as a brace for better contact patch. Sorry for my ignorance.
The Bear
I don't Do Mornings;
So Don't Poke the Bear!!!
huggybigbear is offline
Human Verification
