Old 05-22-2007, 08:33 PM   #11
Member Number: 11540
Re: XM Radio Install - Pics
For those of you that don't want to go to the trouble of routing the antenna on the outside, do what I did. I ran the antenna wire behind the door seal (drivers side on mine) and simply used velcro to mount the antenna end on the dash between the defrost opening and the CS storage compartment. It works great. I also used the same technique in my F150.. Just a thought...
bcmc03 is offline
Old 05-22-2007, 10:41 PM   #12
ldrhawke's Avatar
Member Number: 11385
FUN_MACHINE_90 previously said: View Post
did you turn up the volume on your ipod?...that might make it work if you didnt do that.
YEP! I ordered an iPod interface for the radio so I can control it with the steering wheel buttons.I just bought this iPod/FJ radio interface on EBay. $129.99
2007 TOYOTA FJ CRUISER iPOD DIRECT CONNECT INTERFACE + AUX INPUT
"New!!!! This iPOD direct connect interface will allow you to connect your iPOD directly into your factory radio & give your a additional aux input to your factory stereo. You will be able to control your iPOD through your factory car stereo and your iPOD will charge its battery while connected. For the additional Aux input you can run anything into it via RCA's and switch to that instead of the iPOD anytime by pressing a button on your factory car stereo. This interface is the best solution for adding your iPOD to your factory car stereo. Never settle for a noisy radio frequency FM (RF) modulator / transmitter.
This interface connects an ipod directly to your Toyota audio system. Its on-board software translates commands from your Toyota External CD Changer (You In-dash CD Changer will stil work perfect with this interface installed) controls into commands that the iPOD understands, and provides the following benefits:
• Retains Digital Sound Quality
• Allows you to Control your iPod from the factory radio buttons
• Includes 4ft Cable
• Keeps iPod Charged And Ready To Go and the iPOD will automatically stop charging one hour after the iPOD is paused. iPOD will go to SLEEP mode after charging.
• Control your iPOD from your factory radio and steering wheel controls (if equipped)
• Retains iPod display and Controls"
For the XM....I just realized the Garmin Zumo I purchased for my motorcycle has an XM radio system if you purchased their Xm antenna, which I just did. This is a repost off another post I made.
I bought a Garmin Zumo 550 recently, mainly as a GPS and XM radio for my rally motorcycle. It uses blue tooth for a wireless connection to my helmet. But, as you can see, it also makes a great all around GPS and XM radio for the FJ.
It has the advantage of only paying for 1 XM subscription and having XM a GPS and XM in all you vehicles.
It comes with both a permanent MC mount and a car mount, which makes it quick and simple to remove and remount. It is designed for one hand use on a MC and a touch screen. It is wired so it auto shuts off and comes on when you start the car of MC. I just ordered the XM antenna which allows it to be moved between vehicles and still maintain XM. Or you can just sit around the camp fire and program it using it's built in batteries. Handy not to have to reprogram way points in GPS memory as you change vehicles.
It looks like it was made for the FJ with it's silver and black case. A few photos to tell the story. Mount is perfect for not having to take you eyes off the road while driving. It plugs into the aux. input on the FJ radio. Just under $700 for it on the net.
Gamin Zumo on FJ
Very bright screen easy to read in daylight
XM Radio
On my Yamaha FJR1300
On my Porsche
Little plastic pad that comes with it for dash mount
My dog told me he wants one on his side too.
http://i33.photobucket.com/albums/d84/ldrhawke/fjcruiser-4dr-sunfusion6806.jpg
LDRHawke
St. Augustine, Florida
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, beer in the other, body thoroughly used up, totally worn out and screaming "Holy crap, what a ride!"
ldrhawke is offline
Old 05-22-2007, 11:04 PM   #13
Briman42487's Avatar
Member Number: 7204
looks good.
Briman42487 is offline
Old 05-24-2007, 01:22 AM   #14
Member Number: 11252
Send a message via AIM to rhawbsays Send a message via Yahoo to rhawbsays
ldrhawke previously said: View Post
Very Nice. How is the volume in the AUX. input. I plugged my iPod into it and found it to lose a lot of volume. I had to turn the radio volume all the way up to compensate.
I use my ipod all the time. I just max out the volume on the ipod and then turn it down on the deck.
rhawbsays is offline
Old 05-24-2007, 06:16 AM   #15
Corey's Avatar
Member Number: 2902
Looks good Steve.
I am getting Sirius before to long to integrate with my Pioneer AVIC-D3.
Question for the satt radio users, would not the antenna work in the front dash speaker like I posted here?
http://www.fjcruiserforums.com/forum...-antennas.html
I have the GPS antenna mounted inside there, and it picks up the satts perfectly.
Corey is offline
Old 05-24-2007, 06:35 AM   #16
FJ LE's Avatar
Member Number: 9297
My antenna is installed at the same location as SteveLandcruiser, but for "family viewing" here's where
my unit is located:
FJ LE is offline
Old 05-24-2007, 08:27 AM   #17
RobbTC's Avatar
Member Number: 7171
Send a message via AIM to RobbTC Send a message via Yahoo to RobbTC
After everything was installed, I called XM, activated my $12.95/month service, and I haven't looked back since.
Call them back and tell them you received a post card offering you $77/year. Use code "zwinback" if they ask for a coupon code. Comes out to about $6.42 a month.
RobbTC is offline
Old 05-24-2007, 10:18 AM   #18
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
RobbTC previously said: View Post
Wow. Thanks, Robb!! I'll get right on it.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 05-24-2007, 11:03 AM   #19
smalls's Avatar
Member Number: 3834
Send a message via AIM to smalls
I get a loss of volume with my sirius radio and other mp3 players through the AUX port as well.
- '07 Voodoo Blue, 6speed MT | Upgrade 2 | A-TRAC | RR Locker | Roof Rack
- Mods To Date: 275/70/17 Goodyear Wrangler MTR's | OME Medium Suspension | Sirius S50 | Silverstar Headlights | DRL's disabled | Flowmaster Series 40 | K&N drop-in air filter | Seat belt Alarm disabled | Satin Black OEM Alloys
- Next: Bumper | ARB Rack | Lights | etc.
-Upstate Cruisers-
-Olde North State Cruisers-
smalls is offline
Old 05-24-2007, 11:24 AM   #20
Lobo Loco's Avatar
Member Number: 8583
Nicely done write-ups, but I must say for the XM install you went to way too much work. The Terk - Audiovox unit just plugs in to the FJammer - no holes, no major disassembly of the truck, just pull off the radio face plate and pull the radio out a bit. You don't even have to cut or splice a wire!! let alone drill a hole. Totally integrated with the radio and steering controls. Works great with excellent sound quality. Antenna mounts up the samy as what you have done and you still have the AUX port for your iPod. Cost was $99.00 from XMfan(dot com) last fall. Have heard the price went up a bit, but still a much better option than the factory kit and I prefer it to a bunch a junk hanging off the dash, cup holders, etc. And I speak from experience, as I first had a Samsung Nexus which worked great, but the display was too small and buttons too small to operate easily while driving. My $.02. Any way, XM ( or Sirius if you are of that ilk ) is great and I wouldn't be without it...even going to put it in my FJ40...although I know the sound quality will be diminished with all the other racket that goes with a 40!!
My other FJ is a 40
TLCA #17482
Lobo Loco is offline
