Old 12-09-2007, 04:52 PM   #41
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: GPS: Overhead / Rear-View Mirror Installation Mod
Tubig previously said: View Post
How exactly do you wire the power cable for the GPS? Instead of plugging it in to the Cig Lighter.
I installed a secondary auxillary cig lighter receptacle at the top of the left plastic kick panel (below/behind the dash) and wired that into "switched" fuse terminal via an Add-A-Circuit.
Not only does this end up being the perfect length for the power cable itself, but it also exposes the speaker to the passenger compartment for listening to directions.
I'll post up some pics of that set-up tomorrow.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 12-09-2007, 04:57 PM   #42
Member Number: 8627
thubub previously said: View Post
Steve, great fix, forgive my ignorance, is the 276c a current Garmin model, and if not what has it morphed into?
Yep, the 276C is still a current model.
Amazon.com: Garmin GPSMap 276C GPS Navigator and Chartplotter: Sports & Outdoors
However, some upgraded (more expensive) versions have since been added, such as the 376C and the 498. The upgraded units come pre-loaded with various mapping software (which also can be added to the 276) and a weather channel reception capability.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-09-2007, 07:42 PM   #43
Banned
Member Number: 2259
The catch with the weather channel reception and weather maps is that you have to suscribe to XM Satellite service. Being a Sirius guy, this made the models with more bells and whistles unattractive.
Tony5150RN is offline
Old 12-10-2007, 07:17 AM   #44
Member Number: 8627
Tony5150RN previously said: View Post
That's exactly why I went with the 276C. I figured that a good amount of money spent on a straight-forward navigational device (rather than a combination weather radio / Bluetooth / iTune player / coffee maker / baby bottle warmer), the more likely I would end up with a dedicated unit that performs its primary function the best.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-16-2007, 03:52 PM   #45
FJ-Ollie's Avatar
Member Number: 6685
Overland Journal did a review of 6 different GPSs.
(1) Bushnell ONX 200CR
(2) DeLorme Earthmate GPS PN-20
(3) Garmin GPSMap 276C
(4) Lowrance GlobalMap 540C
(5) Lorance iFINDER Expedition C
(6) Magellan Crossover GPS North America 2500T
Taken from the review:
"...the Garmin 276C finished as my top choice of the group..."
The only downsides mentioned were that only Garmin proprietary maps can be usd in it. The Lowrance 540C came in a close second but didn't quite make it because it was too bulky and Lowrance has no Auto-routing software for its units.
"OLLIE" (AKA: FU-OLLIE)
K6JYB / "Head Butcher"
Check Out "OLLIE's" FJ:
FJ-Ollie is offline
Old 12-21-2007, 11:36 AM   #46
Member Number: 8627
Here's the Garmin Speaker/Power cable and a pic of its installation right behind and at the top of the driver's side kick panel.
I drilled two holes in the kick panel for feeding a pair of cable ties through to secure the 12V cigarette lighter receptacle to the back side of it.
Even at "5" or "6" (out of 10) on the volume level from the 276C, the speaker's volume nicely fills the passenger compartment with clear sound.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-22-2007, 12:19 AM   #47
FJ-Ollie's Avatar
Member Number: 6685
It's amazing how loud these things are. I actually stuck mine in my center console under my fused switch panel. People always ask me where the hell the voice is coming from.
FJ-Ollie is offline
Old 12-24-2007, 10:44 AM   #48
Member Number: 8627
FJ-Ollie previously said: View Post
No kiddin', Ollie. That little thing puts out some hefty sound!!
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-24-2007, 01:58 PM   #49
p3pete's Avatar
Member Number: 16224
Thanks for the great write up! Successfully hard-wired my Garmin NUVI using this thread. Wasn't able to use the same location for the head unit so I put it just to the left of the rear view mirror and ran the power like you did.
Cheers,
Pete
p3pete is offline
Old 12-26-2007, 07:53 AM   #50
Member Number: 8627
p3pete previously said: View Post
Great!! Post up some pics of your installation when you get a chance.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
