Old 12-03-2007, 02:36 PM   #1
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Thumbs up GPS: Overhead / Rear-View Mirror Installation Mod w/ lots of pics!!
If you happen to have a GPS that uses a swivel base mounting system, such as this Garmin 276C . . . .
. . . . you can securely mount your GPS right above your inside rear-view mirror by following these (relatively) easy modification instructions.
Step 1 - Remove your rear-view mirror by sliding off the plastic cover plate and use a Phillips-head screwdriver to remove the screws.
Step 2 - Feed through your headliner (from behind the inside A-pillar cover) any cables that will be necessary to run your GPS . . . . such as a power cord, external antenna cable, etc.
Step 3 - Notch back (cut) 1 1/8" of the sides of the rear-view mirror base so that a flat platform results. (File and paint as necessary.) This will allow the GPS mount base to fit flat against the mirror base. (Please forgive the ugliness of the cut. Fortunately it will be completely covered.)
Step 4 - Drill two holes in the rear-view mirror base that are even with the original holes, but are 5/8" rearward of the original holes. (These will be the new mounting holes through which the OEM mirror screws will go, thus setting your rear-view mirror 5/8" forward towards the windshield.)
Step 5 - Drill a pair of matching holes through the removable circular base of the GPS mount. (Take advantage of an existing hole and add a second hole the same width apart as the rear-view mirror mounting holes.)
Step 6 - Insert the OEM mirror screws through the GPS mount base and the rear-view mirror base, attaching both to the existing ceiling screw holes.
Step 7- A self-tapping screw (for additional support) can be drilled and inserted through the GPS base and into the metal that protrudes slightly beyond the mirror screw holes.
Step 8 - After all screws have been securely tightened, the GPS swivel mount can be attached to the mount base with the thumb screw.
If necessary, rotate the GPS mount cradle for proper orientation.
Step 9 - Install GPS unit into the mounting cradle, connect necessary cables from behind, and adjust the swivel mount for optimum viewing.
Even a large GPS unit like the Garmin 276C GPS will sit above your rear-view mirror, as to not block your rearward view. And, either the GPS unit itself, or the entire swivel mount can be easily removed from your FJ to prevent theft.
Plus, sitting as high as it is within the FJ, little of the GPS can be seen from the exterior.
This GPS mounting modification will result in a very sturdy platform for even the heaviest of GPS units. The swivel base will allow your passenger to rotate the unit in his/her direction. And, since it is aimed at eye-level, noting your location is literally as simple as glancing in your rear-view mirror.
For a similar overhead GPS mounting modification, take a peak at Shadow-Warrior's Lowrance GPS set-up. http://www.fjcruiserforums.com/forum...ll-thread.html
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is online now
Old 12-03-2007, 02:43 PM   #2
Member Number: 10006
Re: GPS Overhead / Rear-View Mirror Installation Mod
Nice install steve. If only my TomTom didn't have the windshield suction cup base i would give this a try. I may figure out something though...
-Benjamin Franklin"
2007 Supercharged Voodoo Blue
-Layton
layonnn is offline
Old 12-03-2007, 04:19 PM   #3
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
Re: GPS: Overhead / Rear-View Mirror Installation Mod
Very nice, I'll probably do this with my Crossover if it will fit.
mattmainster is offline
Old 12-03-2007, 08:47 PM   #4
"MI" FJ's Avatar
Member Number: 10058
Hey "LandCruiserSteve" great timing, I have that EXACT GPS and mount ready to install into my FJ. (Moves from my boat...to the truck...to the snowmobile...and back depending on the season!)
Few quick questions:
Are you still pleased with the installed configuration?
What path did you route the power and external antenna wires?
Where did you mount the external antenna on your rig?
(PS Do you have a photo of the installed remote antenna?)
| '07 | Titanium Silver | 4x4 | 6-Speed MT | CQ | UR #2 | Z1 | PPO | GY |
Mods to date: Bridgestone REVO 285/70/17, CB: COBRA 75WXST, Brandi mt/4' Firestick, PIAA H4 Xtreme White Plus, Engel 45 w/slide lock, Custom Rear Storage Assy, Garmin 276 GPS w/remote antena, 12VDC outlets, Dirty Parts Dual Battery Kit, BadBoy Horn, Tuhle Roof Top Carrier w/Custom Mount, Shovel & Axe Mount, HalGuard Fire Extinguisher, Scan Gauge II, CO2 Air Tank Kit, Sliders, Brush Guard
Future mods: Install ICON Billet Lwr Trailing Links, Install Parrot 3200 Kit, OME Lift, Skids
"MI" FJ is offline
Old 12-03-2007, 08:53 PM   #5
Member Number: 13684
really slick i'll do this thanx..been trying to figure where to mount omne.
knick is offline
Old 12-03-2007, 09:11 PM   #6
Member Number: 8627
"MI" FJ previously said: View Post
Yes. Even more than I thought I would be!! The viewing height is perfect. The controls are easy to reach. It doesn't clutter up any other vaulable space in the passenger compartment. And, it's easy to remove/hide.
Up behind the driver side A-pillar cover, and then across to the GPS under the headliner. (The headliner pulls down easily with the mirror and the sun visors/clips removed.)
I temporarily hooked up one of those suction cup GPS antenna extensions, but I've got a Garmin roof-top antenna on order. (Looks just like a nagnetic satellite radio antenna.)
I'll post up more detailed pics of the actual cable routing when I install the new antenna later this week.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-03-2007, 09:12 PM   #7
Member Number: 8627
Nice install steve.
mattmainster previously said: View Post
knick previously said: View Post
Thanks, guys.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-03-2007, 09:13 PM   #8
"MI" FJ's Avatar
Thanks...just in time for the weekends PROJECT!
"MI" FJ is offline
Old 12-03-2007, 09:17 PM   #9
Member Number: 8627
Great!! Let me see yours when you get it in.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 12-04-2007, 09:07 AM   #10
sonof40's Avatar
Member Number: 11473
Very innovative Steve (as usual).
Added bonus: It covers that one spot that the sun always seems to peek through.
Steve
TLCA 14294
sonof40 is offline
