wiring harness - Toyota FJ Cruiser Forum
post #1 of 9 (permalink) Old 05-23-2006, 02:13 PM Thread Starter
Quoted: 0 Post(s)
wiring harness
Hooked up my wiring harness from toyota to the boat this past weekend.....and..... NOTHING!! No brake lights, no turn signals, no runing lights, NO ANYTHING!! i checked the fuse for towing in the engine compartment, but it is fine. The connections are 4 pins both on FJ and trailer.... any suggestions on what to do??
voodooblue is offline
post #2 of 9 (permalink) Old 05-23-2006, 02:22 PM
Kansas Law Dog's Avatar
Quoted: 19 Post(s)
Re: wiring harness
1. Make sure Port guys plugged the 4 pin connector into the wiring harness on the FJ (this is different than trailer plugged to connector).
2. Use a volt meter to be sure there is a 12V signal to the 4 pin connector.
3. Be sure the ground pin is grounded.
“Kansas Law Dog” for admiration of “Tombstone”, the movie, and the legend of Wyatt Earp.
2007 Titanium 4x4 Automatic (stock except non-factory rock rails)
Kansas Law Dog is offline
post #3 of 9 (permalink) Old 05-23-2006, 02:23 PM
atreu59's Avatar
Quoted: 0 Post(s)
Re: wiring harness
you have a test light? multimeter? do you get juice at the harness when you hit the break?
edit..
LINX KLD!
atreu59 is offline
post #4 of 9 (permalink) Old 05-23-2006, 02:27 PM
Matt07FJ's Avatar
Quoted: 0 Post(s)
Send a message via AIM to Matt07FJ
Re: wiring harness
Did you install it yourself or was it factory installed? I noticed after i had installed mine that i didn't lock the wiring harness into the convertor under the dash good enough and it had fallen out. I hooked it back up and it worked fine. You may wanna make sure that they have the convertor plugged up under the dash.
Matt
'07 FJC - Voodoo Blue - ARB Safari Snorkel, Icon Front Coilovers, OME Heavy Rear Springs, Icon Rear Shocks, All-Pro Extreme Upper Links, 17" Stock Steelies, 34x10.5x17 Superswamper LTBs, ARB Winch Bumper, M8000 Winch, ArmorTech Offroad Rear Bumper, Everything Blacked Out
'96 Lexus LX-450 - Black -Factory Locked Front and Rear, OME Suspension, Slee Sliders, 305x70x16 BFG A/Ts
'99 4Runner - SR5 Sport - Factory Locked - Sold
'07 FJC - Sun Fusion - Sold
My Buildup
TLCA Member #16924
Matt07FJ is offline
post #5 of 9 (permalink) Old 05-23-2006, 02:52 PM Thread Starter
Quoted: 0 Post(s)
Re: wiring harness
Thank guys Ill give those a try tonight --ill let ya know ( by the way --it was installed at the dealer)
post #6 of 9 (permalink) Old 05-24-2006, 11:46 AM Thread Starter
Quoted: 0 Post(s)
Re: wiring harness
Ok , there is power coming from the fj harness (accordong to the meter) but no lights are working on the boat trailer. Tried hooking up the trailer to the other vehicle and the lights work fine WTF!!
The plugs on the fj and boat trailer are both the same (appear to be anyway) 1 ground and 3 prong..... Any ideas ?????
post #7 of 9 (permalink) Old 05-24-2006, 12:39 PM
CornerCanyonFJ's Avatar
Quoted: 0 Post(s)
Re: wiring harness
Prongs wired the same?
Titanium 6M/T CQ UR 37 P7 C7 Added: Rock Rails and Front Skid Plate; Traded: Dash; Sold: Dash Cluster
The journey is the destination.
The laws of flotation were not discovered by studying the sinking of things.
CornerCanyonFJ is offline
post #8 of 9 (permalink) Old 05-24-2006, 12:45 PM
Quoted: 19 Post(s)
Re: wiring harness
First check to be sure that the fj tow hitch 4 pin connector ground pin is in fact grounded. Lights will not work unless there is a proper ground. Use ohm setting on multimeter (not volt meter) to ensure ground pin and frame give positive reading. I'm betting on this being the problem.
If grounding checks out, use a couple jumper wires (4 pin connector to boat trailer connector - one live and one ground) to be sure left turn signal in fj is sending to left turn signal on boat trailer. Right, and brakes to follow.
post #9 of 9 (permalink) Old 05-24-2006, 12:53 PM Thread Starter
Quoted: 0 Post(s)
Re: wiring harness
thanks-- I'll try that
Human Verification
