Corey previously said:
Dualing bandi's
NICE !...
KD7NAC_07FJ previously said:
And the first Bandi Mount Mk II is MINE!!  and paid for to
Congrats KD !!!...
gpwdFJ previously said:
Bandi,
Good to see you back in the saddle again! I think the passenger side mount looks a little out of place, but I also don't think there is a better place for it to be mounted either, so good work!
now we can get dual phase!
Does anyone know if the height difference will cause any issues?
I am a CB dummy.
Thank You !!...
The idea for this for the bandi mount II was
designed for ease of mounting (as the first
one was - just bolt on), and for the use of
two different type antenna setups, as in
maybe HAM and CB, or even as a flag mount...
As far as dual antenna, and mounted so that
they are at the same height, can be done by
using this same mount, but you will need to
drill two holes in the side of the door jam for
for it to be mounted to, which is great cause
you do not have to drill a hole in outside face
of the door, and it could always be removed
and two plastic push plugs put in... but there
may be an issue with the separation distance,
I am no CB guru either, but I thought it had
to be 60" ?...
The only other option for a non-drilling location
would be at the lower striker on the door, but
it really did not line up right there... IMO...
I like the location as I have it now, it sits well
being lined up at the bottom of the pass. side
light, and if you look at the FJ, it really is not
symmetrical to begin with (ie: spare, lic. plate,
windw hump, etc...)...
AF Chief previously said:
Installed by Bandi mount yesterday. Great product.
Thank you so much, AP did a great job at
replicating it, and so it would be cost effective...
Glad you like it !...
