I submitted my own picture for it, and she is adding text to it too on both sides.
If you are in WA. state and near my town, you can ge the poles here.
Bent Bike Motorcycle Salvage
4337 Auburn Way N
Auburn, WA 98002-1310
(253) 854-5605
4337 Auburn Way N
(253) 854-5605
I will snag a picture of mine tomorrow.
She thinks it will be in the mail here by Saturday.
Cool thing is her flags are $15 for the ones already made up with her designs, and the custom ones you have her make are the same price.
She is really nice to work with.
I found her site with Google searching for "ATV flags."
I also ordered a heavy duty Firestik spring, quick disconect for a CB antenna like I use now, and I will use those with the flag pole.
Going to mount the pole on a hitch shank to go into the Toyota hitch.
Corey, I found mounts, and flags, on her site but no poles??? Can you give me a link to each part I'll need minus a flag??
She does not carry the poles yet.
She is thinking about it.
Her mounts or poles she carries are to week for a 4x4.
Hers are meant for quad runners.
Your best bet is to do a search for your area for a custom motorcycle/ATV shop, and ask them if they carry the Firestik brand of poles.
If you do a search here for user BT17R, you will see his setup and Firestik pole.
I went with the 7' model.
You could also call up Firestik to see if they know any dealers in your area.
For the heavy duty spring and qucik disconect, I get my CB stuff from www.walcottcb.com
You will need a longer bolt that goes into the bottom of the spring when bolting it into a tralier hitch.
I am not sure of the length yet until I buy a new shank.
BT17R said he used one for a Tacoma I think, and got it at the dealer.
The flag came today, and it mounts to the Firestik pole perfectly.
Barbara includes a small hose clamp and tie, but it is not needed.
Just remove the red tip from the pole, and slip the new flag on.
You will have to move the Firestik black grommet on the pole down a few inches to accommodate the bigger flag.
You can also order the same spring without the two electrical connectors shown.
I goofed on my order
Now all I have to do is take my old hitch shank from my '90 truck I pulled the tent trailer with, take the ball off, and get a longer bolt like Bob did and some big washers for it.
The flags themselves have to be 9' off the ground for visibility.
Shortly after 911 I like many other Americans ran an American flag on my 4Runner.
I put it on my 4' Firestik II antenna that was mounted to the fender.
This was before I got the ARB and put the antenna on it.
When the flag was on the antenna, it whipped it back and forth, and at times I thought it would tear out the mount on the fender.
You can see here the mount. http://pnw4runners.com/tando/qd.jpg
Flags need to be put on a separate pole just for them, and mounted in a sturdy mount such as the Bandi mount or on a trailer hitch like BT17R did.
