Is there a battery available now that works well? - Toyota FJ Cruiser Forum
 31Likes
post #1 of 42 (permalink) Old 03-10-2017, 06:36 PM Thread Starter
Quoted: 19 Post(s)
I know the reverse polarity terminals really limit our options, but it seems like there should be one that works. I'm on my fourth Sears DieHard Gold in a little over three years. That battery is dead every single time I try to start my FJ. It sucks having to remove the battery and carry it up to my apartment to charge it every single time I need to drive. I've seen several recommendations for the Platinum one that is a real Odyssey, so it is not as horrific quality as the other Sears batteries, but it is no longer sold.
Been to Sears, Batteries Plus, several auto parts stores and several Interstate dealers, and they have no options other than the DieHard one that is just garbage.
It sucks that Toyota made the decision to screw us by being too cheap to put the negative terminal towards the center of the car. The Panasonic battery that came in it lasted seven years so it's just sad other makers can't make a batter that lasts more than a few months.
jenjen is offline
post #2 of 42 (permalink) Old 03-10-2017, 06:42 PM
Winter Admin
Winterpeg's Avatar
Quoted: 1474 Post(s)
Re: Is there a battery available now that works well?
I jammed in a big blue top Optima with no issues and no need to change any battery cables.
It's great having 900 CCA.
EDIT: I've had this battery for almost 5 yrs... no issues. I do have the alternator modifier that gives me more volts and I top it off every once in a while with a decent trickle charger to make it smile
Suck it up... it's only -40
________________
2008 FJ Trail Teams
ARB Front; Exp1 rear STC; Apex rocksliders; Lightforce on front bumper; ARB Full Rack w/Grid; ; Icon Susp w/cdc; magnaflow muffler (mashed the original); Engo 12000S winch; 285/75/16 Duratracs; Ricochet skids, Uniden PC78 Elite CB (ch 16 typically, ch 19 on the hwy)
"Don't drive angry".... BFM
Winterpeg is offline
post #3 of 42 (permalink) Old 03-10-2017, 07:29 PM
GT_Charlie's Avatar
Quoted: 45 Post(s)
I know of no good reason why four Sears Diehard Gold batteries would go bad in four years. Do you have a static drain when the ignition is off?
The reason I ask is that my son installed an amp for his subs and wired it directly to the battery so it was on even when the truck was parked. He had problems with terminal corrosion and dead batteries constantly! I checked it out and was like, uh, ... that ain't right!
Charlie
RomaBoy likes this.
Yes officer, I know I that smell like beer. I'm not drinking it, I'm wearing it!
GT_Charlie is offline
post #4 of 42 (permalink) Old 03-10-2017, 07:53 PM Thread Starter
Quoted: 19 Post(s)
> big blue top Optima
I thought they were garbage since they moved production to Mexico. I had a yellow top in my FJ for about two months, and it failed pretty quickly. I couldn't get it to charge over 11.5V no matter what I tried including hitting it with a 180V capacitor and a 20 Amp charger which caused it to vent.
jenjen is offline
post #5 of 42 (permalink) Old 03-10-2017, 08:05 PM
pop
Quoted: 85 Post(s)
You live in the United States ? Never a problem finding a battery. Most batteries have a reverse post mate. Like a 27 or a 27R. Look up BCI Group Numbers, Dimensional Specifications, Polarity & Terminals for batteries.
CurbCrawler likes this.
pop is offline
post #6 of 42 (permalink) Old 03-10-2017, 08:06 PM
scrufy's Avatar
Quoted: 40 Post(s)
jenjen previously said: View Post
> big blue top Optima
Don't know about them being garbage unless they changed since 2013. Put a yellow top in mine in 2013 and have a very high draw compressor and winch. All is well 4 years later.
Irving Zisman likes this.
13' Cement TT / Titanium Muffler Bearings
scrufy is offline
post #7 of 42 (permalink) Old 03-10-2017, 09:47 PM
Winter Admin
Winterpeg's Avatar
> big blue top Optima
I'm by no means an expert..... but I now have 2 of the same blue top Optimas in my FJ.... I also put another one in my mom's motorhome.
No issues.
As mentioned previously..... I would be taking a long hard look at your electrical system. To go through that many batteries, no matter the quality, is very unusual.... unless you are in Dubai where they chew through batteries every year due to the heat.
amaclach likes this.
________________
2008 FJ Trail Teams
post #8 of 42 (permalink) Old 03-10-2017, 10:04 PM
Forum Beer Miester
Thorn661's Avatar
Quoted: 962 Post(s)
As @Winterpeg mentioned it's all in the upkeep gentlemen. Should you choose the route of the big boys (AGM, GEL) be prepared to Mod your stock charging system or they WILL FAIL. AGM battery's cannot take a consistent low charge i.e. below 14.1 volts or they will degrade prematurely, do your homework first then make an informed purchase and install based on those parameters.
There are some really great threads here on the subject of proper charging and the mods required, make use of them.
Winterpeg and 10851 like this.
Thorn661 is offline
post #9 of 42 (permalink) Old 03-10-2017, 10:47 PM
adam12_4's Avatar
Quoted: 184 Post(s)
Put in a Duracell from SAMS 4 years ago when my Panasonic went & works great.
[SIGPIC]07 Sun fusion MT 887X OME Bilstein 5100 TRD short throw shifter Overhead console MOD TRD intake, ARB front & red eye rear bumpers Flow master CAT back EXH 9500 Engo Winch Demello Hybrid sliders Snorkel lefty T case
adam12_4 is offline
post #10 of 42 (permalink) Old 03-11-2017, 04:53 AM
dscotty's Avatar
Quoted: 35 Post(s)
Send a message via Yahoo to dscotty
Consider another OEM Toyota Battery. I got a new one underwarranty when my 30 month old went bad following one too many jump start assists. I don't know what they cost, but I was pleasantly suprised it was the same exact OEM model. Lots of posters on this forum have had good luck with it. I abused the original and accidently drained it all the way down several times. I've only had the new one a few weeks now, so take it for what it's worth. I'll be sure to go on a rant if it doesn't last at least 5 yrs as a daily driver.
dscotty is offline
Human Verification
