OEM Subwoofer request - Toyota FJ Cruiser Forum
post #1 of 2 (permalink) Old 03-12-2017, 11:47 PM Thread Starter
djsupanova1's Avatar
Quoted: 0 Post(s)
I have looked through a quite a few posts on the subwoofer option for the truck on here and all I seem to find is guys who tell you how they modified theirs and slam the factory setup. I'm an OEM guy. I want all of my car to be as 100% OEM as possible.
So my question is...
Does anybody have all of the part numbers for the factory sub option? Also, what parts, if any changed from the early build 2007-2009, to 2010-2014? I'm currently adding the option but need the wiring harness that goes from the enclosure to the plug mounted on the top of the wheelwell. I would also like to know if there is anything except the unit itself, console button and wiring harness that I may be missing. I would like a confirmation of the part number for the fascia I have to replace that covers the wheelwell electronics (I have the tray style cover that comes with non sub FJ's obviously). I believe I already found out, but I'd like the hard number that is imprinted in the plastic.
I want to point out that The sub box I got is off a 2012. As I mentioned above, I have a 2007. What differences am I going to encounter, If any?
I would appreciate any pictures of YOUR OEM setup as well.
Please, if you want to reply with information about anything NOT OEM, don't waste your time, EVERY other post about the Subwoofer option already does this and you can just add to those threads. In other words, Don't be a dick
Thanks in Advance!
djsupanova1 is offline
post #2 of 2 (permalink) Old 03-19-2017, 09:16 PM Thread Starter
Quoted: 0 Post(s)
Re: OEM Subwoofer request
The 2012 Sub wiring is not compatible with my 2007. I went to the dealer. The guy behind the desk said if I had the earlier model sub, it would be just about plug and play. The one I have has the amp built into it, but two harnesses coming out (there is only one one connector mounted to the wheel well).
Can anybody confirm that this wheel well connector is for the older style sub? If you could remove the trim piece under the sub, and take some pics, I'd love to see them!
Thank You very much.
Human Verification
