Old 10-24-2008, 04:36 PM   #11
FJ THIS's Avatar
Member Number: 17242
Re: ScanGauge Installed on Left Side of Dash
NDA431FJ previously said: View Post
I mounted mine on the rear view mirror. Attached to the mirror frame with 3M double side tape. I extended the ScanGuage II cable using a straight through RJ-45 coupler and a std. CAT5 network cable.
Did you need to buy the "extension cable" to mount your Scangauge up there ?
FJ THIS is offline
Old 10-29-2008, 11:55 AM   #12
FJ THIS's Avatar
Does anybody else know ?
"Do you need to buy the "extension cable" to mount your Scangauge up there ?"
FJ THIS is offline
Old 10-29-2008, 12:04 PM   #13
Eagle Scout's Avatar
Member Number: 17710
FJ THIS previously said: View Post
yes you do.
My deceased FJ (R.I.P.):
BRAVO28POINT2
My new FJ Build:
(Shhhh.... Secret Secret)
Eagle Scout is offline
Old 01-30-2009, 08:36 PM   #14
JBIRD8403's Avatar
Member Number: 15604
Location: Carson/great lakes where the navy takes me!!!
Send a message via AIM to JBIRD8403 Send a message via MSN to JBIRD8403 Send a message via Yahoo to JBIRD8403
i am just bought one and i am planing on installing it just like you did but i like a more cleaner look....so what i will do is from my understanding there is a port in the back of the SG and i will pop out the silver piece and cut a hole so taht the cord could fit through so you wont be able to see the cord at all...
Jonathan
2008 Sandstorm/4x4/AT/Pkg. Option E/Roof Rack/tow package/All Weather Floor Mats & Rear cargo*Tint, Alpine IVA-W505, Alpine Nav, TRD CAI, Clifford alarm, ARB compressor, demello slidders, Pro Comp recovery gear, hella black magic, blue sea fuse box, air dam, FOX 3" Lift Fully Adj w/res, AP 2"stiffer rear springs, also AP A-Arms, 285-70-17 BFG A/T XD series hoss, demello front bumper!
Special Amphibious Reconnaissance Corpsmen
JBIRD8403 is offline
Old 04-07-2009, 06:13 AM   #15
Member Number: 23508
I like the way you mounted the gauge. Can you tell me where you get industrial velcro? Thanks Dan
dyna is offline
Old 04-07-2009, 01:47 PM   #16
23V
23V's Avatar
Member Number: 10063
dyna previously said: View Post
I had some left over from a trade show booth I worked on a little while ago. I think you can get it at True Value or Ace Hardware or in a pinch from Amazon:
Amazon.com: Velcro Industrial Strength Sticky-Back Hook & Loop Fasteners, Black, 2inX15 Foot Roll (VEK90197): Office Products
'07 FJ Ti
Revos, Kenwood DNX5120 + Alpine PDX4.150 + DLS Ultimate UR36i components + custom 10" subwoofer enclosure, M-PAC Rear Cargo Rack, ScanGauge II, DeadBolt spare tire lock
23V is offline
Old 04-26-2009, 02:48 PM   #17
I like your setup, but I can't find thats its clear behind where you drilled the hole. It's a hardplace to get at with your hand. How did you drill the hole, in steps or what? Thank Dan
dyna is offline
Old 04-27-2009, 02:49 PM   #18
23V
23V's Avatar
I removed the silver trim piece before drilling the hole. As I recall, there wasn't anything tricky about it. It pivots up from the bottom and then pulls free at the vent opening.
Drilling the hole was easy once the piece was removed. Afterward, I routed the OBD II cable down to the connector under the dash and then snapped the trim piece back in place.
'07 FJ Ti
23V is offline
Old 06-28-2009, 07:51 PM   #19
patrixmith's Avatar
Member Number: 6279
I'm getting ScanGauge in a week or two.
I was planning on putting the unit in the exact same location, but instead of routing the cable to the side and drilling a hole through the side of that silver panel, I was planning on drilling a hold directly on the face of the silver panel (since there is a 2nd input on the ScanGauge on the back of the ScanGauge unit) and having the cable run straight into the unit so no cables are showing.
What do you guys think? Only drawback, a hole on that panel, but the ScanGauge will cover that up.
patrixmith is offline
Old 06-28-2009, 07:53 PM   #20
patrixmith's Avatar
Member Number: 6279
Oh, and one question for you 23V: How does that silver panel come off? Does that piece snap off separately, or do you need to take off the entire dashboard?
