I was looking for a small SPDT (on - off - on) switch to wire my Swiss Map Light to also work with the door. The only switch small enough I found says it is for AC.
Can any of you who are much more electrically inclined tell me if this switch will work with 12v DC?
Thanks!
'07 Sun Fusion, Trail Gear Sliders, OME 883, painted Alloys, painted bezel and bumpers, SAS Scanguage II Maplight, SAS Fog Light kit, PIAA bumper kit, A-TRAC, AFE CAI, URD Y-Pipe, BajaRack and ladder
because you want an on-off-on switch, you'll have to buy the switch body and rocker seperately. take a look at the spdt V-series rocker switch body and the Cortura II nav light rocker, blue lens VVAYCBL-197. together, it should cost you less than $12 + s&h
Eric
2008 Sandstorm FJ
1989 Dodge Raider (broken)
1987 Toyota 4wd pickup (dismantled to frame for sandblasting)
1992 Eagle Talon AWD (broken)
Hmm, thanks for the tip and a place to buy switches. The problem is that I have less than 1 square inch to place the switch. These switches look bigger. Do you know the size of their switches?
The V-series rocker switches won't fit. They require a .830 X 1.45 hole.
Thanks!
What amperage are you using the switch for? An AC switch can be used for DC you can't however use an AC relay for DC unless it is dual rated, the same applies to circuit breakers. A switch is just a physical contact between two conductors, it doesn't really care AC or DC just ensure that the switch is of the proper amperage to supply your load and add a little buffer in there for good measure.
In general I over compensate wire size when i design for DC since you will get the same voltage drop for AC or DC for the same amperage but when working with 12v DC it is a much greater percentage of the overall voltage. Also there is a little difference in ampacity based on skin effect which in general lowers the ampacity of copper in DC applications. So yes an AC switch can be used just oversize it a hair. This is more important as the amperage of the load increases so for larger loads it is advisable to always go with DC rated parts just to be safe
2008 6MT Sandstorm Convenience and Offroad package,
black tundra door handles
blacked out mirrors
tow hitch
SCUBA MOD DONE
trail gear sliders,
Cobra 75/bandi mount/3' firestik
2 4" Kragen HIDs
various slider/frame/differential scratches.
AllPro Ultimate lower links
Sway away front coilovers
OME mediums in the back.
Total chaos UCAs
Generally 12 and 24 volts are considered low volatage DC.
blacked out mirrors
tow hitch
SCUBA MOD DONE
trail gear sliders,
2 4" Kragen HIDs
Total chaos UCAs
