Old 12-31-2008, 11:47 AM   #11
TinCan's Avatar
Member Number: 16596
Re: Is it the Autostart Sys. causing check engine light & loss of Traction Control sy
mitchm previously said: View Post
I will give this a try, however I may have to disconnect the battery first to clear the lights, and its a bit cold out there -9*F. I will post the results.
Food for thought; The auto start does not cause the lights to come on every time that I use it, but the lights only come on if the Auto stat has been used.
Right, the remote starting, throws the lights because there is a chip in the key that is NOT being read when the car is started. This is why you shouldn't have the lights coming on with a normal key start.
TinCan is offline
Old 12-31-2008, 12:18 PM   #12
gsgmac's Avatar
Member Number: 1534
If it was a immobilizer/key issue, the vehicle would not start at all. I believe it is related to the wiring of the auto-start to the ignition harness. There are TWO starter wires that must be used, if only one is used, you will have the described problem.
Use both wires and DO NOT connect together:
Starter green/black + ignition harness / Connect to alarm starter wires (this usually includes the starter kill, should be two wires and the grn/blk wire is cut).
2nd Starter black/white + ignition harness / Connect to Relay (see below) and do not cut, this wire just needs to be energized for auto-start.
Using relays is a lost art these days, use the diagram below for the second relay:
See my post for more details:
http://www.fjcruiserforums.com/forum...tml#post279045
Also, find a shop that knows what they are doing and does not start blaming the vehicle or dealer for their mistakes or lack of knowledge.
Vice President of TTR
1972 Freeborn Red FJ40 4x4
gsgmac is offline
Old 12-31-2008, 08:05 PM   #13
Two60zCowboy's Avatar
Member Number: 21615
I would look at one other thing also. I have a 2008 TT and I just finished this install last week.
All the wiring list that I was able to get my hands on say that the accessory wire is the white/green wire @ ignition harness.
There is also a blue/yellow wire @ ignition harness. This wire controls the heater blower motor. Turn on your heater - trace it back to the fuse panel and unplug it. The heater will turn off.
That white/green wire is the accessory wire and it controls the idiot lights. If your installer is tapping into this wire for the remote starter accessory (heater) connection then he is loading down the idiot light circuit and throwing alarms. Use the blue/yellow wire for your accessory connection.
Or it could be the 2nd relay. I did both, the relay and the blue/yellow wire; my trouble ended there.
It's a complicated problem. I spent days racking my brain.
Good Luck!
Two60zCowboy is offline
Old 01-06-2009, 10:07 PM   #14
mitchm's Avatar
Member Number: 20196
Thank you all for your help,
Not only does the auto-start system work like it should, I can finally enjoy driving around in a warm car without my dash being lit up and not having any traction control. "actually liked not having the tractin cotrol but the lights were very annoying"
Rather than dig into this myself when I had already paid someone to do the work, I brought some info in from the last two posts to the people who had installed the system. Although I could tell they were still convinced that it had nothing to do with the Auto start, and as they were ready to tear the system out. I asked that they at least check into from what I had read to be the two most likely solutions.
What they found was that both starter wires were connected, and that it was in fact the W/G accessory wire that was connected and causing the alarms, connecting to the BL/Y corrected the problem.
One difference that I noticed right away was that when auto started just the heater and lights came on, no radio compass or inclinometer.
Once again Thank You all for your help, hopefully someday I can return the favor.
mitchm is offline
Old 01-06-2009, 10:13 PM   #15
SKINUM's Avatar
Member Number: 18535
Send a message via MSN to SKINUM
Thank you Two60zCowboy.
Thanks for the info maybe I can get mine fixed now.
$22,500
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
Old 01-07-2009, 12:27 AM   #16
mitchm's Avatar
Ouch,,, I spoke too soon.
Apparently I was overly confident that they had fixed the problem, LIGHTS ARE BACK ON...
I have decided that I am not taking the vehicle back to these guys even if it meant a refund,
Looks like I am going to have to get my hands dirty and see what I can find...
mitchm is offline
Old 01-07-2009, 05:58 AM   #17
bncsauve's Avatar
Member Number: 5410
The FJ has two starter wires in its wiring harness. Starter1 and Starter2. Installers don't understand the uses for both and tend to twist them together. It works, but, doing this appears to bypass the neutral start switch, if you look at the schematics. You need to have them add a relay for the starter2 wire to keep it separate from starter 1 and your problems will go away. Sorry, I didn't read all the posts before writing this. An earlier post by gsgmac describes this.
We're now a two FJ family
Black Diamond and Black Cherry
bncsauve is offline
Old 01-07-2009, 10:24 AM   #18
TinCan's Avatar
bncsauve previously said: View Post
You need to add diode, so that starter 1 doesn't backfeed. http://www.fjcruiserforums.com/forum...rs-1304dp.html
This could help end a lot of this, I wrote this post awhile back for 07's but still do-able with a toyota bypass box
TinCan is offline
Old 01-07-2009, 11:12 AM   #19
mitchm's Avatar
Right, I brought a hard copy of the Starter Wire/Relay Diagram into the installers. However my next step is to clear out the garage and verify exactly how they have it wired.\
TinCan previously said: View Post
Once I verify the way it has been wired I will look into this as well.
Thanks.
mitchm is offline
Old 01-07-2009, 11:16 AM   #20
SKINUM's Avatar
Thanks.
Good luck because I have no idea what im looking at under there. If u figure it out take some pics..... and help a brotha out!
$22,500
SKINUM is offline
