Old 01-07-2009, 01:50 PM   #21
api510's Avatar
Member Number: 17306
Re: Is it the Autostart Sys. causing check engine light & loss of Traction Control sy
TinCan previously said: View Post
You need to add diode, so that starter 1 doesn't backfeed. http://www.fjcruiserforums.com/forum...rs-1304dp.html
This could help end a lot of this, I wrote this post awhile back for 07's but still do-able with a toyota bypass box
My installer told me that a bypass would be needed for the remote start to work on mine too. From what I understand, the bypass does away with your transponder key altogether. You either need a new key or the installer said that he could take apart my existing key and put a new cover on it (only so it wouldn't be so bulky).
api510 is offline
Old 01-07-2009, 02:50 PM   #22
bncsauve's Avatar
Member Number: 5410
99% of the connections will be inside the cab, inside the dash and lower side panels. Make sure you have a good light. I would suggest soldering any connections they made with crimps. Good hunting!
We're now a two FJ family
Black Diamond and Black Cherry
bncsauve is offline
Old 01-07-2009, 11:30 PM   #23
Two60zCowboy's Avatar
Member Number: 21615
Yea Tincan is right, there is some feed back getting to that idiot light circuit. It is the second starter relay that you need to put in. I was troubleshooting two problems at the end of my install. The heater was not coming on and the idiot lights; so I troubleshot both, the blue/yellow wire and the second starter wire, at the same time. Everything worked right. So I stopped right then and there and hurried and solder everthing together and never looked back.
Not to throw more sh!t out there but, I followed compustars diagram for adding a secondary starter relay. Their system has a 2nd Starter 250mA (-) negative output that is connected to the relay. But I would guess this is the circuit Tincan is talking about
"You need to add diode, so that starter 1 doesn't backfeed. DIY FJ Remote Start RS-1304dp"
Just saying, check your prestige autostart install directions for this application, then you wire in the second starter relay accordingly and you should be set.
There is solution, I'm only a DIY'er. Hope you get cause it is sweeeeeeet when it's working right.
Two60zCowboy is offline
Old 02-01-2009, 05:19 PM   #24
Member Number: 24207
Had the same issue.....finally so pissed about it, changed to a regular alarm without the remote start.
LYNH12 is offline
Old 02-02-2009, 02:35 AM   #25
gittyup's Avatar
Member Number: 22447
I am having the same problem. I will be talking to my installer tomorow and giving him all this info.
Thanks,
Hopp
07' FJ 4x4 AT Titanium metallic
TRD exhaust, K&N drop in
Pioneer F90BT, Infinity Kappa 6x9s, Orion 275 & 222
db 10"subs & 3 1/2s are here but not installed yet
Tires (5 Maxxis Buckshots)
Tuffy Light Bar w/ 4 cheapy lights for now
Code 3 Blue/White LEDs
Cobra 19 LTD
Future Mods:
1.Bumper replacement
2.Snorkel
Lift... and the list goes on
http://www.cardomain.com/ride/3227890
gittyup is offline
