Old 04-11-2007, 05:38 PM   #111
TJ Cruiser's Avatar
Member Number: 3134
Re: Cobra 75 WXST and Bandi Mount Install
BDFJ, I like the look with the 2 footer, thats what I was thinking of getting.
Black Diamond FJC 4x4 AT Loaded. Revtec 3" Lift, Tires-33 x 12.5 R 20 TOYO Open Country M/T....Wheels:Gear Alloy , 713 MB, Double Pump, 20 x 9 www.sun1.netwww.dirtycruisers.com
my scuba driving video-http://www.youtube.com/watch?v=k7DPRFMBXDc
TJ Cruiser is offline
Old 04-11-2007, 09:26 PM   #112
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
OK so i really am a noob about c/b but i have a 75 wxst but i was given a 4 foot 5/8 wave fire stick is this ok to use?
im slowly getting parts together
1.Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
2.STOP DRINKING THAT YELLOW KOOL AIDE IT MESSES YOU UP INSIDE!
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers , all-pro front sway bar links
thugasaur is offline
Old 04-11-2007, 11:52 PM   #113
stunaep's Avatar
Member Number: 10583
does it matter what order the spring, quick release, and the other screw on parts go?
i want to put them in a different order... i've seen different orders on different rigs. i can't imagine it would make a difference?
--c
stunaep is offline
Old 04-12-2007, 09:46 AM   #114
bandi's Avatar
Member Number: 2261
Does not matter what order they are !!!...
but as long as the Antenna is on the Top...
Also, if the spring is on the bottom, there
will be more leverage at wok against the
spring, and if on top, there will be less
leverage against the spring...
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
Old 04-12-2007, 12:48 PM   #115
stunaep's Avatar
bandi previously said: View Post
so, put the spring on the bottom? that is what we want, right?
--c
stunaep is offline
Old 04-12-2007, 01:02 PM   #116
bandi's Avatar
Member Number: 2261
stunaep previously said: View Post
--c
Putting the spring on first(bottom) and then the
disconnect will allow you to attach a second item
(ie flag pole, road wip antenna,etc) and to be
able to utilize the same spring for either... Or you
could put the disconnect in first, this way when
you do remove it, there is nothing left mounted to
your Fj but the disconnect stub... It's really a
preference thing, depending on ones use...
Hope this helps... or did I double talk again..
bandi is offline
Old 04-12-2007, 04:22 PM   #117
stunaep's Avatar
nope... perfectly clear... i was thinking there really wasn't any particular order, but was thinking about what to take with me and what i'd leave on the cruiser...
--c
stunaep is offline
Old 04-12-2007, 09:30 PM   #118
TJ Cruiser's Avatar
Member Number: 3134
Trying to figure what parts are a must have...... Why the quick disconnect and the spring? Doesn't the quick disconnect make it easier to be stolen? Isn't the antenna flexible without the spring? I guess I could see switching between a 2' trail lenght antenna and maybe a 4' highway antenna..??????? But again, just keep a wrench to change antenna's when needed. Removing antenna for auto car washing?????
Old 04-12-2007, 09:38 PM   #119
stunaep's Avatar
...well, the spring just keeps it flexible... the whip is flexible, but the spring is just SUPER flexible...
but the quick release is so you will take it off and throw it in the back of the rig to KEEP it from getting stolen...
i've decided, to put in this order:
female quick release, part (screws into antenna cable adapter)
large dual female receiver bolt, part
spring, part
antenna...
so, i can take the most important stuff with me, AND if someone wanted to steal the base, it does them no good on it's own... i can always bolt it down, but then it has to stay on, and while it's not likely to be stolen, the antenna isn't cheap!
--c
stunaep is offline
Old 04-12-2007, 09:56 PM   #120
Mtbcoach's Avatar
Member Number: 2433
TJ Cruiser previously said: View Post
Quick release works both ways, easy to steal, easy to take off so it doesn't get stolen. No, the antenna isn't what I would call "flexible", nothing I wold want to be banging into tree limbs and such. The spring helps reduce any damage from low heights.
I think that the parts list at the beginning of this thread is very comprehensive and a "minimum" list for a reliable off-road setup...
'07 GSJ15, well enhanced
'97 FZJ80 OME J
'71 FJ40 stock
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
