Old 10-16-2007, 12:56 PM   #181
felonious's Avatar
Member Number: 12866
Re: Cobra 75 WXST and Bandi Mount Install
I haven't seen any covers big enough to cover it but I like the idea now the hunt begins.
felonious is offline
Old 10-16-2007, 01:59 PM   #182
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
i was thinking of using the little spot right next to my rear cup holder for the plug i dont put anything there and it keeps the mic handy (its a square space half inch deep)
1.Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
2.STOP DRINKING THAT YELLOW KOOL AIDE IT MESSES YOU UP INSIDE!
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers , all-pro front sway bar links
thugasaur is offline
Old 10-16-2007, 02:01 PM   #183
felonious's Avatar
Good idea but the problem is if a drink spills there you are in deep s**t because it will flood out the socket then drip down into the control box.
Old 10-16-2007, 02:51 PM   #184
thugasaur's Avatar
Member Number: 691
that cup holder is my change holder! i have a camel back on the drivers seat no spills plus there is a cap for my handset plug to cover the port from drips or spills
"Church" V2.0
2007 Voodoo 5AT 4x4
Old 10-16-2007, 03:27 PM   #185
felonious's Avatar
the tricky part will be mounting the receiver box because the cable is not very long so you would have to mount it close to the little recessed spot in the console.
Old 10-16-2007, 03:49 PM   #186
thugasaur's Avatar
Member Number: 691
ive got a auto so im pretty sure there is some room under there if not ill have to figure another location (sucks) im just waiting on my cell phone replacement to show up so i can call the solder joint (i have no long distance on home phone) to price my cable and its go time
"Church" V2.0
2007 Voodoo 5AT 4x4
Old 10-19-2007, 06:45 PM   #187
felonious's Avatar
Its not a clearance issue there its just that under the pocket there the cable wont reach down to the truck floor to mount the unit. As for the cable if you need help sottering on the cable end its no problem if you come to the CB shop I'm not that much further if you need help on install also have a swr meter to be able to tune it.
Old 11-10-2007, 07:54 PM   #188
Mr R2FJ's Avatar
Member Number: 14854
Send a message via AIM to Mr R2FJ Send a message via Yahoo to Mr R2FJ
I just wanted to add a note here to make sure people do not over tighten the fire ring portion of the bandi mount. If you over tighten the bolt you can and probably will damage the ring. I did this and spent several hours on it before I figured out what was going on and I spoke to another guy today at a local meet that did exactly the same thing. Basically there is a solder join in the ring that breaks when you over tighten the main bolt. It twists it in such a way that will make you crazy trying to figure out your horrible SWR readings.
I know several people have mentioned that they "really had to crank down on it", but I just wanted to let people know that they shouldn't tighten down excessively unless they have to. If you properly remove the paint and get good metal to metal contact, normal torque on the mount should be fine.
Hope this helps others from repeating my mistakes.
Mr R2FJ is offline
Old 11-11-2007, 10:54 AM   #189
Nevada_FJ's Avatar
Member Number: 3784
felonious previously said: View Post
well here is the final pictures of the antenna and mount with the tail light guards.
How did you mod the bandi mount to fit?
Nevada_FJ is offline
Old 11-12-2007, 10:53 AM   #190
mikemayberry's Avatar
Member Number: 12675
Felonious, is it possible to do your install and to also put a jumper jack to jumper from the WX75 to the AUX jack and use the radio speaker?
I am going to do what you did, but add a jack above or below the handset plug so I can make the aux speaker jump to the AUX plug when desired.
Based upon your experience, do you think this will work? I think I read that someone had tested the connection and found the EXT speaker will feed the AUX feature of the radio.
Thanks!
M
vOOdOO Blue 2007 with 3" Ol' Man Emu Lift
XD Diesel Custom 17x9 w/ Destination AT Tires, Auto, All the 2007 Options
ARB Front Bumper and 12k Winch
and now Towing the newly introduced PacMule Trailer
mikemayberry is offline
