Old 06-11-2009, 01:02 AM   #271
Administrator
five-by-five's Avatar
Member Number: 14804
Re: Cobra 75 WXST and Bandi Mount Install
Nuthin' wrong with that, just check it occasionally for nicks from the great Texas scrub brush.
05/06 built '07 6MT accessorized with the following:
Extreme Truck Toys 3" spacer lift, Demello front, single hoop bumper + skid plate, K&N CAI Intake as reviewed here, Trail Gear sliders, Cobra 76 XTR CB, A-TRAC hax and custom trail rash from all over Texas.
five-by-five is offline
Old 06-11-2009, 01:41 AM   #272
drummer22's Avatar
Member Number: 23265
Alrighty thanks. I just got under it and that made sense to me. Just wanted an experienced set of eyes to look it over ha
Don't mess with Texas
Hook'em!
drummer22 is offline
Old 06-11-2009, 09:24 PM   #273
drummer22's Avatar
I'm getting reading of just above 2 on the SWR meter. Does this sound like a grounding issue or "tuning the antenna" issue?
(I have the 3ft Firestik antenna and on the back of the package it says that its tunable. I think by turning the tip on top....)
Hook'em!
Old 06-11-2009, 09:57 PM   #274
CactusJK's Avatar
Member Number: 1157
Probably grounding. What are your readings on channels 1, 19, 40?
drummer22 previously said: View Post
K7JNZ
CactusJK is online now
Old 06-11-2009, 10:12 PM   #275
drummer22's Avatar
On channel 1 it was about 2.3
On channel 40 it was about 1.75
Didnt take a reading on channel 19. Will do next time I try
Hook'em!
Old 06-11-2009, 10:32 PM   #276
Administrator
Sounds like tuning or needing to find a better ground plain.
Old 06-12-2009, 01:16 AM   #277
drummer22's Avatar
yeah i went out and shaved a little more powder coating off of the bandi mount. going out tomorrow to test! ill let yall know. btw thanks for everyones help, especially to bigbill
Hook'em!
Old 06-12-2009, 02:37 PM   #278
drummer22's Avatar
Is the squelch supposed to be set at max or min?
But regardless, I am still getting pretty bad SWRs (I tried with max and min squelch). On channel 1 I was getting above 2 and on Channel 40 I was getting 1.75.
On channel 20 I was getting about 3!
Then I went out and turned the little tip on the antenna all the way to the top. This made it worse as my SWR readings jumped up about 1.
Any suggestions?
Hook'em!
Old 06-12-2009, 02:59 PM   #279
Administrator
Small adjustments on the antenna are best.
Squelch is to block out the static in the background. It has nothing to do with your SWR's.
If your in the city and there is a lot of interference then you turn the Squelch up to block the "noise". If your in a good area with little static, turn the Squelch down so you can hear further.
Old 06-13-2009, 10:25 AM   #280
BlackIceBob's Avatar
Member Number: 12895
Quick install question: I am putting most of my "Bandi mount" stuff together today.... Did anyone use any LocTite (or any other brand) of thread compound between the quick-release/stud, quick-release/spring, or spring/antenna? It just as a thought to me it might hold it secure....but it might also affect SWR.........
Thoughts?
2008 Black Diamond, Offroad Package, CO, CF, EL, OEM Roof Rack, Toytec 3" lift (FJ3-RCC), TRD exhaust, white grille bezel, Quickfist/Maglite grab handle, Swiss Army/Hella fog lights, Hella Supertone horns, groovy Quick Fist shovel & axe mount. A whole lot more to come.
Keep away from people who try to belittle your ambitions. Small people always do that, but the really great make you feel that you, too, can become great. --Mark Twain
TLCA Member #18690
Made in Japan, but BUILT in the U.S.A.
BlackIceBob is offline
