Old 11-17-2009, 07:18 AM   #1 (permalink)
Member Number: 31956
radio and dash clock dead
The radio and the dash clock are dead...checked the 2 stereo fuses in the main fuse box...any ideas?
westTXcrd is offline
Old 11-17-2009, 07:25 AM   #2 (permalink)
Member Number: 13241
Re: radio and dash clock dead
is it the stock radio? have you ever removed the radio? perhaps the connectors came off?
You may want to disconnect the negative battery connector and then reconnect it (sort of a re-boot if you will).
marlinsfan is offline
Old 11-17-2009, 08:56 AM   #3 (permalink)
Member Number: 5363
Send a message via AIM to landy
keep looking at fuses in both fuse panels. I can't see any reason other than a fuse somewhere.
Landy
TLCA #20142
BlueRibbon Coalition #51107
2008 Voodoo Blue 5AT
Landy's "Speed Killer" Build-up!
landy is offline
Old 11-17-2009, 11:14 AM   #4 (permalink)
SafetyDave's Avatar
Member Number: 13956
landy previously said: View Post
Clock fuse is in the engine compartment
The Tick!
"Wicked Men! Cease your antics, or I may be forced to assault you with the U.S. Postal System!"-Tick
Click the " The Tick!
" above for my build up and to follow the Adventures of The Tick!
SafetyDave is offline
Old 12-25-2009, 10:22 PM   #5 (permalink)
Member Number: 15874
any update, i just blew mine out. Clock Radio And Cigarette lighter.
Grimeyfella is offline
Old 12-27-2009, 08:43 AM   #6 (permalink)
SurfishinFJ's Avatar
Member Number: 23257
Check the under dash fuse panel. It should be the ACC fuse, bottom row, second from the right. 7.5 amp.
SurfishinFJ is offline
