Old 10-16-2006, 12:22 PM   #1 (permalink)
TheDon007's Avatar
Member Number: 6523
Factory Sirius Questions
Greetings all:
The vehicle I traded had satellite radio, and man I sure do miss it. I have been studying the factory Sirius unit, and have read through some posts where there was a glitch. With this in mind, I have the following questions that I would like to present to the floor:
1) Has the previous mentioned Sirius glitch been fixed?
2) Does the Sirius channel, artist, and title information appear on the factory radio display (FJammer)
3) Is the clarity such as you would expect? I'm curious if the signal is modulated through the radio, causing you to increase the volume output over that of your FM radio volume levels.
4) Is the antenna mounted on the front of the roof, or on the rear? I have a roof rack, which I thought would interfere with the signal.
Any other guidance or expertise would be greatly appreciated.
TheDon007 is offline
