Old 11-04-2006, 06:57 PM   #1 (permalink)
redfernsoljah's Avatar
Member Number: 6109
Wiring Diagram FJ Cruiser
Could someone sticky this or put wher it needs to be for others benefit.
Thanks, Stephen
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE/BLUE AND BLUE/BLACK (+) AT IGNITION SWITCH
Ignition 1 BLUE/YELLOW (+) AT IGNITION SWITCH
Starter 1 BLACK/WHITE (+) AT IGNITION SWITCH
All Door Trigger GRAY/RED (-) AT BODY ECU
Domelight Super WHITE (-) AT VEHICLE FUSE PANEL UNDER DRIVERS SIDE OF DASH
LF Latch RED/BLACK (-) AT BODY ECU
MUST DIODE ISOLATE EACH WIRE
RF Latch GREEN/YELLOW (-) AT BODY ECU
LR Latch PINK/BLACK (-) AT BODY ECU
RR Latch PINK/BLACK (-) AT BODY ECU
Trunk Trigger WHITE (-) AT BCM ATTACHED TO REAR OF FUSE PANEL UNDER DRIVERS SIDE OF DASH
Alarm Disarm USE KEY SENSE GREEN/YELLOW (-) AT SWITCH OR BODY ECU
Parking Lights GREEN (+) AT BCM ATTACHED TO REAR OF FUSE PANEL UNDER DRIVERS SIDE OF DASH
Low Crr Pk Lights GREEN (-) AT SWITCH
Convenience
Headlights-Lo RED/WHITE (-) AT SWITCH
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb GREEN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb GREEN (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights WHITE (-) AT SWITCH
LF Hazrd Bulb BLUE/WHITE (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb PINK (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb BLUE/WHITE (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb PINK (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo BLUE/BLACK (+) AT SWITCH
Wipers-Hi BLUE/RED (+) AT SWITCH
Trnk Release BLUE/RED & BLUE/BLACK (REV) AT MOTOR IN REAR DOOR
Remote Start
Ignition 2 BLACK/RED (+) AT IGNITION SWITCH
Accessory 1 WHITE GREEN (+) AT IGNITION SWITCH
Starter 2 GREEN/BLACK (+) AT IGNITION SWITCH
Key Sense GREEN/YELLOW (-) AT SWITCH OR BODY ECU
Tachometer UNCOMMON COLOR (AC) AT INJECTOR OR COIL
Speed Sense VIOLET/RED (AC) AT ECM BEHIND GLOVE BOX
Low Crr. Pk Lights GREEN (-) AT SWITCH
Brake Lights GREEN/YELLOW (+) AT SWITCH
Reverse Lights RED/YELLOW (+) DRIVER KICK
Horn GREEN/RED (-) AT COLUMN
Modules
WIRE LOCATION
Module 1 BODY ECU IS PART OF THE JUNCTION BLOCK UNDER DRIVERS SIDE DASH TO THE RIGHT OF FUSE BOX
Module 2 ENGINE CONTROL MODULE IS BEHIND GLOVE BOX
Doorlocks/Windows
Power Unlock PINK (-) AT BODY ECU
SINGLE PULSE UNLOCKS DRIVER DOOR DOUBLE PULSE UNLOCKS ALL DOORS
PowerLock BLUE (-) AT BODY ECU
Driver Mtr Unlock BLUE/RED (REV) AT BODY ECU
Driver Mtr Lock BLUE/BLACK (REV) AT BODY ECU
Pas Mtr Unlock BLUE/RED (REV) AT BODY ECU
LF Window Up BLUE (REV) AT SWITCH IN DOOR
LF Window Dn BLUE/BLACK (REV) AT SWITCH IN DOOR
RF Window Up BLUE (REV) AT SWITCH IN DOOR
RF Window Dn BLUE/BLACK (REV) AT SWITCH IN DOOR
redfernsoljah is offline
Old 01-02-2008, 03:57 PM   #2 (permalink)
Member Number: 6109
Re: Wiring Diagram FJ Cruiser
bump
4x4 AT Black Diamond
#56003
CQAT, DLAT, GYAT, TR10, CR10, TU50
Icon Lift, All-Pro Front Bumper
Old 01-02-2008, 04:44 PM   #3 (permalink)
stringmachine's Avatar
Member Number: 7766
there is a wiring pdf on the forum already, unless this has more info than it does. thanks for posting anyway.
stringmachine is online now
Old 01-02-2008, 04:46 PM   #4 (permalink)
Member Number: 7766
electrical schematics??
