Man you have alot of speakers going on
A few things... Does the crossover of the addawoofer allow for the components to be connected to it as well?
How often do you have passangers in the rear?
The easiest thing to do IMO is let the rear pillars go, they will do virtually nothing for you in the front especially with the very limited range of the 3 1/2 speakers.
I would really recomend a 4 chan amp if the setup allows for it and run the 61/2 off the front chans, and the 5 1/4 off the rear chan. If you can't run the 3 1/2 and 6 1/2 together i would run the 3" and 5 1/4 off the deck and the adawoofer off the amp. Just remember to put some caps/bass blockers in line with the speakers. You will need a high to low adapter for the amp, and i would run it off the front speaker output of the radio to have them run from the same chan as the front dash speakers to keep your fader more or less correct.
If you have not purchased the equipment yet, what i would do is simply run RCE216 in the front and RCE213's in the back. Mount the front speaker's tweeter on the dash where the 3 1/2 was. Get a 4 chan amp to run the whole thing, I would recomend the Alpine MRPF450 ~$200. If you want to keep the rear pillar speakers leave them running by the radio, but i would really disconnect them.
That will give you a good combination of control and sound quality.
Running 4 pairs of speakers probably would not give you the best sound performance vs 2 pairs of well balanced speakers.
Hope that helps.
Keyek previously said:
