Old 11-26-2006, 05:41 AM   #171 (permalink)
RIG-57's Avatar
Member Number: 2463
Re: turn the DRL's OFF!
doing undercover in an fj? does that work? they kind of draw attention to them selves don't they. would make it a little hard to tail someone i'd think.
RIG-57 is offline
Old 11-28-2006, 08:12 AM   #172 (permalink)
BDFJ's Avatar
Member Number: 6261
[quote=Kzoocruiser;254676]
Joe Lech III previously said: View Post
OK so we all know how to disable our DRL by disconecting the the connector behind the headlight or by pulling the emergency brake and turn off and on FJ.....
the million dollar question is, has any one run a switch to the dash so you can turn them on and off??....QUOTE]
Yup. Works great. Used the Taco switch.
-Jim
NorthWest FJ Cruiser Club <<— NEW PRIVATE FORUM ONLINE!!!
PDXTuning Dyno Pull
Purchased: '07 BlackDiamond AT · UR2 · CQ · GY · C7 · EL · Skids · Sills · Rubber Mats
Aftermarket: 265/70R 17 BFG ATs · Trail-Gear Sliders · FormFit Hood Protector · Matching Tint · AVS Visors · Dual PIAA Horns · ScanGauge II · Schrader's Flag Mount & Tri-Mount · BandiMount · Galaxy DX 45MP CB with Firestik II
Mods: Lucrum Winch Mount & Warn M8000 — OME 3" Lift
TRD Stuff: Exhaust · Cold Air Induction
BDFJ is offline
Old 12-04-2006, 09:58 AM   #173 (permalink)
bigbill25's Avatar
Member Number: 1293
RIG-57 previously said: View Post
i was at a drive in theater this summer, glad i didn't take the fj. the drl's would have been a pain when i started thre motor to get a little ac relief during the movie.
As the very first post in this thread now says, the DRL's would not come on unless you took off the parking brake...
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 12-04-2006, 08:40 PM   #174 (permalink)
MichEE's Avatar
Member Number: 7210
Thanks for ALL of the info gang... I am going to do the quick and easy connector mod. Wife has driven off with DRLs on and no tail lights!! Oops.
Not sure why this has taken 18 pages of this forum though!
What's your excuse??? Ti, 5AT, Hand Controls, hitch, 10sNE1?
MichEE is offline
Old 12-13-2006, 05:56 PM   #175 (permalink)
Skinpuppet's Avatar
Member Number: 442
Send a message via AIM to Skinpuppet
Did everything I possibly could to try and pry the connector
off there but nothing was working. My hand fit in there ok and
tried for about 15 minutes. Pulling the fuse doesn't work so I'm
not sure what to do. Maybe have someone do it unless there is a
trick someone has.
Skinpuppet is offline
Old 12-13-2006, 07:25 PM   #176 (permalink)
BDFJ's Avatar
Member Number: 6261
It took me about 6 tries over two days. It does disconnect.
Try, try again.
-Jim
PDXTuning Dyno Pull
BDFJ is offline
Old 12-13-2006, 07:53 PM   #177 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
you DO have to depress the release button first. it's here.
"We are not at our best perched at the summit. We are climbers, at our best when the way is steep"
-John W. Gardner
Taira
Dragon is offline
Old 12-13-2006, 08:17 PM   #178 (permalink)
BDFJ's Avatar
Member Number: 6261
Yes. And it's inset and very stiff. As said 10-12 other times in this very same thread: It's a BIATCH!!!!
-Jim
PDXTuning Dyno Pull
BDFJ is offline
Old 12-13-2006, 08:52 PM   #179 (permalink)
MichEE's Avatar
Member Number: 7210
Dragon previously said: View Post
Yep, not easy. It helped me if it was turned or tilted up a little. Smaller hands work good too if you have a small handed friend!
MichEE is offline
Old 12-13-2006, 08:56 PM   #180 (permalink)
Moderator
Ridge111's Avatar
Member Number: 2612
Body position is important. Seriously. Put your left hip against the bumper directly in front of the headlight and use your left hand. Palm facing the rear of the truck, wrist bent backwards, use your index finger to push the release and slide the plug towards the driver side fender.
Ridge111 is offline
