Shop around before you buy an "all-in-1" kit. Some tend to be way overpriced. However, after saying that, I usually pay a little more and buy the components individually so that I can choose the specific items (fuse holders, ground blocks, proper RCA cable lengths... etc) that I want. You will need power (long) wire, ground wire (short), engine compartment fuse holder, firewall grommet, power wire splitters or rear fuse block, ground block and/or splitter, smaller power and ground wire, RCA Cables, Turn on lead (if using the factory head unit you can use the sub wiring harness in the right rear),........
How many RMS Watts?
With 2 amps I would recommend a 4-gauge kit with at least a good 1 farad cpacitor. If you are going to push more than 1,000 watts - maybe a 2 gauge kit and a good 2-3+ farad capacitor.
Where are you installing the amps?
I would get something with at least a 20' power wire to reach about anywhere. (I am putting mine behind the rear seats and 25' is way too much.)
Will your amps take a speaker level signal? If not, and IF you are planning to use the factory head unit, you will need a speaker level to RCA level converter.
Speaker wire - You can use the factory wiring, but would have to cut the factory wiring harness - I am running 16-gauge to all of the speaker locations - Bet I have used over 100 feet - but am wasting some of that by cutting it before I run it.
You really need to give us more information............
Steve
