Old 11-15-2006, 01:21 PM   #1 (permalink)
n928kc's Avatar
Member Number: 6960
Heated Mirrors
Has anyone successfully installed heated mirrors? I work at a glass shop and have opened up the doors and found the conduit going thru the door panel into the cabin, unfortunatly, the conduit is sealed and plugged , so there was no way to run a wire from the mirrors back into the cabin.
i already have a switch & relay and the heat pads to apply to the back of the mirrors. all i need is a way back into the fj.
my only solution that i can come up with is to install the switch and relay in the door panel and run the drivers side off the switch. any help would be appreciated
n928kc is offline
Old 11-15-2006, 01:27 PM   #2 (permalink)
Razor J's Avatar
Member Number: 4495
Send a message via MSN to Razor J
Re: Heated Mirrors
BigBill may have some info in this thread that could be helpful:
Heated Signal Mirrors
Razor J is offline
Old 11-15-2006, 02:47 PM   #3 (permalink)
n928kc's Avatar
Member Number: 6960
Re: Heated Mirrors
i read all posts at that thread,
but the question is... has anyone been able to get from inside the door to inside the cabin?
n928kc is offline
Old 11-16-2006, 08:03 AM   #4 (permalink)
Razor J's Avatar
Member Number: 4495
Re: Heated Mirrors
Understand your question now-sorry I don't know
Razor J is offline
Old 11-16-2006, 08:47 AM   #5 (permalink)
8INTEXAS's Avatar
Member Number: 6111
Re: Heated Mirrors
I am not sure if this is applicable, but when I installed fog lights I used a wireless switch so that I did not have to run a wire through the firewall.
8INTEXAS is offline
Old 11-16-2006, 11:51 AM   #6 (permalink)
n928kc's Avatar
Member Number: 6960
Re: Heated Mirrors
ill do a search for a wireless switch. if you have a link that would speed up my looking
thank you
n928kc is offline
Old 11-16-2006, 04:40 PM   #7 (permalink)
8INTEXAS's Avatar
Member Number: 6111
Re: Heated Mirrors
I don't have a link but any PeP Boys or Auto Zone carries them.
8INTEXAS is offline
