Re: Suggestions for Amp and Wiring Placement
I'll take a crack at this first.
Amp placement - most are sticking under seats or mounting in rear area (trays mounted to panels, etc.). for under seats, you'll likely lose your vent under there, and you've got to watch your dimensions.
Wires are either down the center console or along the sills. Avoid having power run close to anything else, and if you do, aim for a perpindicular cross over.
Don't worry about installer knowing or not knowing the FJ. If they know what they are doing, it will be fine. The FJ is a very open platform for audio wiring.
