Old 01-16-2007, 11:05 AM   #1 (permalink)
slim's Avatar
Member Number: 8636
Inverter Questions
If your vehicle wasn't equipped with one, do they have a "hack" like the atrack for the install?
If a hack isnt possible, is there a 12v source in the right rear where you could install an after market inverter? or do you need to run a 12v line?
slim is offline
Old 01-16-2007, 12:08 PM   #2 (permalink)
jeshua's Avatar
Member Number: 6888
Re: Inverter Questions
I remember some one putting the stock oem inveter into there Fj and it wasn't wearth the trouble he had the hardest time finding the right wires and getting everything hooked up right. I would recomend getting an after market one and putting it in were ever you want. I plan on doing this in the future and will put it in the back like the oem is and also add a 12v outlet in the back as well. I will do a little searching for you and see if I can find the post
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-16-2007, 12:12 PM   #3 (permalink)
Member Number: 8006
Easy to use a plug in inverter. Unless you have a daily need for one.
TIMECRUISER is offline
Old 01-16-2007, 12:21 PM   #4 (permalink)
jeshua's Avatar
Member Number: 6888
I couldn't find the thread I wanted but here are two good ones
How to add another 12V power outlet
400 Watt outlet install ??
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-16-2007, 12:40 PM   #5 (permalink)
slim's Avatar
Member Number: 8636
thanks.
slim is offline
Old 01-16-2007, 05:32 PM   #6 (permalink)
bugs1961's Avatar
Member Number: 3569
Send a message via Skype™ to bugs1961
I put an inverter into my FJ and wrote it up. Do a search for "400w inverter installation" and you'll find it. It's working great so far.
bugs1961 is offline
