This is a question to those who have installed new sub amps. i searched, but didn't find much.
Has anyone ran 2ga, or 1/0ga wire for your higher powered sub amp??
If so, how did you route it?, and if you routed it inside, did it leave really bad lumps?
I'm considering routing either inside frame, i will inspect for roughness first, and use non-slitted wire loom. Or tying under truck, routed along drivers frame rail, to the inside and going nuts with zip-ties, making sure its not in a danger zone, oh, and it'll be wire loomed this way as well.
Any info is appreciated. thx, Power.
'01Jetta turbo. loaded,sold x-mas eve. More mod money!!
'03chev 2500hd 4x4 crewcab,33s xterrains,locked leveled, 4.10s' traded for below, and it had heated mirrors. i miss em'
'07 FJ, bfg's, avs,t10001bd, 2-10in/w6-v2s, 4 farad cap, 0ga wire, more soon. acquired 10/7/06 lovin it
Everything I learned in life, I learned from watchin' P@rn... And while drinkin'.
oh, and no, i don't like to capitalise, unless i'm bored. so take it like the bicth u are
If you can get by with 4G wire, there is a pre-drilled, ready to go hole just opposite side of the glove box. It can feed right down to an amp under the passenger seat.
thx bang, and cow, but i will be running about 1200watts rms. i might be able to get by with 4ga, but 1/0 is what the amp manufacturer suggests. so at the least i'll use 2ga, which is pretty much 2x the dia. of 4ga. The most that i'll normally push with 4ga is 500watts rms. I guess i may have to try using the under the vehicle method. there is a grommet in the jack stow area that i could modify and re-seal, didn't have enough time to look into it as much today(taxes, and 22 degrees out{high}).
I am slow at doing my installs, picky, and no garage. Now no 2nd car either, so i have to be able to button back up to drive it. I should be getting my amp thursday, and subs prob. friday. However i missed a call by the box builder, might be a delay, or i might use generic box for a while. No custom box out yet that'll fit what i want and have optimal airspace. I will post how i ran wires, and prob pics... when im all done.
i was looking at mine and i am definitly going with 1/0, about 2k watts rms, same thing i had in my old truck. i was looking at the firewall, plenty of room to drill, and just going down the kick panel and in the door sills. i havent popped one up yet and peeked underneath, but i havent ever been in a car that 1/0 wont fit.
I dont see a problem with making it fit, just i hate the "bulge" that normally occurs after you put back together. i have noticed normally worse under rubber floors. if you run yours, take pics, i still have my amp on order, and my subs too.
trust me, there will be no bulge. you wont ever know its under there. i forgot to take a peek at the door sills today. i am a freak and perfectionist. i wont do anything unless i have to skills, time, and tools to do it right. well i have two of the three, now if i find a nice 3 day weekend, then it might happen.
still thinking about running in frame, i'll see when all my shti comes in.
Pull up your door sills there should be plenty of room under them to run your wire.
- Thomas Paine
