i have a problem with my radio the frequences are in odd number and i want it to be in even or both anyone can help in finding a way in doing that
thanks
thanks
???? I'm confused....The dial should allow odd and even numbers
This is indeed the case, European frequencies will be even, which is why American radios will often not work there, or will have a "zone" setting to change tuning.
jtinidaho previously said:
I believe that, in the U.S., FM stations are only odd numbers after the decimal.
For example 94.5, 105.3, 93.7, etc.
This is why the radio has no even numbers after the decimal point.
FM frequencies are odd numbered due to the fact that the bandwidth for FM frequencies is 200 KHz wide. The center of the band is 100 KHz, and because FM is 88 - 108 MHz, the first channel spacing is 88.1 MHz. Allowing for 200 KHz of separation, the next channel would be 88.3, 88.5, and so on.
Slàinte mhor a h-uile là a chi `s nach fhaic!
For so long as 100 men remain alive, we shall never under any conditions submit to the domination of the English. It is not for glory or riches or honours that we fight, but only for liberty, which no good man will consent to lose but with his life. - THE DECLARATION OF ARBROATH, 1320
so that means i can get it starting with 80.0 for me to get 80.2 or 80.4 as an example
Nope. Internally, the frequencies are being passed through various filter stages that rely on the odd numbered frequencies in order to extract the intelligence from the carrier frequency. There is simply no way of reassigning the FM frequency band to accomplish what you are looking for.
