sooo, i hooked up my xbox to my pioneer avic-d3 on the av1 input.. i didnt buy my FJ with the a/c plug in the back of the rig so im trying to just get a simple d/c to a/c power inverter to give the xbox some juice when the passenger gets bored.... i read that the xbox pushes out about 70w so i got the 75w inverter, aaand it obviously isnt working. makes a buzzing sound when its plugged in and creates lines in the screen.
the next size up was a 150w converter.. now i know the d/c outlet is 120w max, but would this 150w converter work and only use the 120 max? or would it just crap out? any help would be most appreciated, xbox in the car is a MUST.
The 150W is just the rating. You are free to use only 20W, 30W, or whatever or more, up to the 150W, although a quick rule of thumb for safety is stick to 80% of max. The device that is plugged into the invertor will determine how much power it draws. Now, I am not sure about the Xbox, but some devices take their timing, or sync signal off the AC line, and seeing as invertors can introduce terrible noise on the AC, you may have an issue. Some invertors are better than others at producing a clean signal.
Slàinte mhor a h-uile là a chi `s nach fhaic!
For so long as 100 men remain alive, we shall never under any conditions submit to the domination of the English. It is not for glory or riches or honours that we fight, but only for liberty, which no good man will consent to lose but with his life. - THE DECLARATION OF ARBROATH, 1320
In regards to invertors, look for pure sine wave inverters over modified sine wave inverters. As pure sine wave inverters have very low distortion due to introduced harmonics, (unwanted frequencies as a result of producing a modified sine wave). Some laptop computers or game systems will not run with modified sine wave inverters, due again to clocking issues and introduced harmonics.
As for brand recommendations, I do not have any at this moment, but starting with pure sine wave inverters is a good step.
Think of an Xbox as a small PC requires much more power than a PS2.
We typically use a 400w-600w inverter, Monster 300Watt worst great, otherwise your local Kragen/Autozone/Pepboys will have one, usually about $30-$40, Monster is about $80 I think.
Also, with larger inverters you will want to run power directly from the bat, not from another wire in the car. Obviously make sure you fuse and put a switch on it if the box does not have 1.
I installed a 400w inverter from Pep Boys and put the outlets in the center console and in the left rear side panel and have been very happy with the results. Also installed two additional 12v outlets, both powered from different sources, wired to handle 15 amps (180w) next to the 110v outlets. With three 12v outlets and two 110v outlets everyone has one to use.
