Just thought I would let you all know. $200 bucks for lowance 250c iways on a website i buy my pilot gear from. It is Usually $350, could be a good deal if you are low on cash.
Voodoo Blue 4X4 with AT.
Added: Warn M8000, Factory rack, Factory hitch, Toytec lift (FJ3-FRCC), Amp-Fortyone-2 Black Alloy wheels with Nitto Terra Grappler 295/70/17, Cobra 75 WXST, Square Sliders, roof rack light bar with 4 Pro Comp lights, 2 Pro Comp lights on custom tube bumper, FJ battery clamp (Thanx Noisycow).
DIY Projects completed:
Toytec lift install, Sliders, body mount chop,Bandi Mount,hitch & tow ring, roof rack light bar and LCNW style bumper.
thanks, i was shopping for a c320.... anyone know if any sd card will work with this unit? granted all sd cards are the same but not sure if they can lock out any outside brands.
An SD card is an SD card, any registered brand card will work, all you should make sure of is that the card has the actual "SD" logo on it, if it doesn't, it's probably going to disappoint you.
If you're talking SD vs mini SD then there is a difference (physical size and capacity) .........however they now have sleeves to slip the mini into so it'll fit in the standard size SD slot on your device.
I just re-read this and it seems confusing.... is it?
Has anyone tried Telenav?
It can be used on GPS enable phones like the Blackberry. No expensive hardware to buy...just download and go! I have had it for over a year now and it works great on the streets and in the woods.
2007 FJ Cruiser - Black
2006 Denali XL - White
2003 Lexus is300 - Black (trade-in on FJ)
1997 Yamaha Blaster
1993 KX 125
