Old 03-11-2007, 07:32 PM   #1 (permalink)
2007fj's Avatar
Member Number: 4059
speaker clipping
IM running a alpine pdx 150 rms per channel amp to 6 1/2'' kenwood components rated at 60 to 240 watts and I am getting clipping.It sounded incredible for about 30 minutes and is now clipping.Any advise on whats going on.
2007fj is offline
Old 03-11-2007, 07:36 PM   #2 (permalink)
RipsFJ's Avatar
Member Number: 3866
Re: speaker clipping
What HU are you using?
Black Cherry, Rock Rails, Roof Rack, VIP Alarm, Tint, 3M Protection Film, Tow Hitch & Converter, Pioneer P6800DVD, JL 450/4 Amp, JL 500/1, JL Prowedge, Fosgate 3Sixty.2, Morel Elate 9 speakers, Momo Shift Knob, Nitto Terra Grapplers, TRD Exhaust, QuickShifter, CAI, Shocks/Struts.
RipsFJ is offline
Old 03-11-2007, 07:38 PM   #3 (permalink)
2007fj's Avatar
Member Number: 4059
avic d3
2007fj is offline
Old 03-11-2007, 07:41 PM   #4 (permalink)
2007fj's Avatar
Member Number: 4059
I should add that IM also running a pdx 1.1000 amp with a 4 guage wire running both amps through a distribution block.But like I said it sounded great for a while.
2007fj is offline
Old 03-11-2007, 07:46 PM   #5 (permalink)
AceTechno's Avatar
Member Number: 4098
First of all Speakers don't "clip". Speaker might be at full excursion. That means you have pushed it as far as it was designed to move. Amp's are what "clip". Clipping is a square wave as seen on an osilloscope. Also knowen as distortion. Your amps output has more distortion than its input. I know this because I have been in Audio since 1989. Try turning down the bass or running a bigger cap. on your mids to cross them up higher as to roll off any unwanted bass. If you can not fix this or don't know how, here is a simple fix... Turn the volume control to the left a little. This will keep the amp from clipping. Good Luck!
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is offline
Old 03-11-2007, 07:46 PM   #6 (permalink)
RipsFJ's Avatar
Member Number: 3866
The amp is clipping because of the signal from the deck. Where is your gain set on the amp? What about the x-over freq?
RipsFJ is offline
Old 03-11-2007, 07:56 PM   #7 (permalink)
2007fj's Avatar
Member Number: 4059
I turned down the gain to .05v which helped a little.I am currently not running a cap .The crossover freqencies are at factory kenwood settings.
2007fj is offline
Old 03-11-2007, 08:02 PM   #8 (permalink)
RipsFJ's Avatar
Member Number: 3866
You have a built in x-over in the amp .... use it. Set it on HP for 100 HZ, I believe that amp comes with a 12db slope. Should help the clipping out.
RipsFJ is offline
Old 03-11-2007, 08:08 PM   #9 (permalink)
AceTechno's Avatar
Member Number: 4098
I would mess with the crossover some what. Cross them mids at 100-200HZ up. The smaller the mids the higher up on the crossover I would go even to 400HZ if need be. Just know that bass+ adjustments in the stereo will distort your system as will having the gain up to high. Remember its better to have a clean sounding system than a loud system. I know 99% of people here will disagree i bet. If you want your system to thump try turning the gain on the amp to the mid/highs down and bass amp up and keep bass adjustments in the head unit flat. It should not matter on the head unit if it is loud at 10 or 50. Once it distortes it distorets. From their the only thing you can do is turn the volume down.
Old 03-11-2007, 08:53 PM   #10 (permalink)
2007fj's Avatar
Member Number: 4059
O.K I figured it out .We put a dvd in earlier and changed the sound to theatre and it screwed everything up.I set it back to off and its back to normal and sounds great.Thanks rip and ace.I just back tracked to what happened before the clipping and realized I changed the dvd sound settings.Strange how much effect that has.
2007fj is offline
