I have replaced my factory sub & amp with my own, and would like to mount my amp on the side wall where the factory sub once was. However, now that the factory sub is gone I am wondering if there are replacement panels that cover up the holes the sub once sat in?
Yes. Just go to your local dealership and have them look up the part #. I did the opposite and installed the factory sub thus needing the other panel. I think it was around $50.00
__________________ 2007 Titanium Metallic and YES I wheel it! TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids Daily Driver:2005 Toyota Tacoma C cab http://www.gclcny.com/ http://fjcruisernortheastrun.org/ http://tlca.org/
Is the factory harness there for the sub, even though my car came without it? Just wondering, since i would like to add the factory sub. Skertes, did you sell yours already?
Yes it's clearly visible as soon as you remove the trim.
might be too late, but if you sell or purchase a factory sub from someone here, you can usually just exchange panels with one another. I did it with two sub sells and both parties were very happy to get ride of their cubby lid, cub interior, cargo tie downs, and wheel well cover in exchange for your wheel well cover.
cool, thanks. Now just have to decide if i want the factory sub or should i just put in an aftermarket 10" sub. I don't need it to be rocking my neighbors, just want a little more bass for some songs.
