Old 07-02-2007, 09:32 PM   #21 (permalink)
Singha's Avatar
Member Number: 12233
Re: Dual Horn Install Project
Hammer_In_Hand previously said: View Post
Just out of curiosity.. For me and those who aren't concerned with the horn being too loud.
Will the HL85115 Supertone horn kit work as well, given the same instructions and parts.. aside from the fuses? I mean.. I would like to be downright obnoxious- on top of being able to attract the attention of fellow FJ owners, naturally.
I have some Hella Supertone in my Honda. These are loud. These will definatley come with me to the Fj once I purchase it. This will be the third vehicle my Supertone get to go on. But I might get a second set to go into the Fj and run a switch to activate the second set as needed.
With the Supertone, I highly recommend running a new harness with relay, the one that is included from Hella is perfect. Awsome quality and thick gauged wire. These draw some amperage when you are on the horn. Also I would just create another harness from the factory horn socket to the relay or the new horn. I am not into cutting things off my vehicle if there is no need to. Just my .02 cent.
Singha is offline
Old 11-28-2007, 10:59 AM   #22 (permalink)
CactusJK's Avatar
Member Number: 1157
Did you go with the 400/500 and use the supplied brackets? Are they symetrically mounted on right/left sides of the grill?
Swingshiftworker previously said: View Post
I installed the PIAA horns too. Just installed the right horn where the OEM horn is attached, hot wired each horn to the single horn wire with a quick connect, and, after sanding away some paint to allow contact, grounded both horns behind the bolt attaching the left horn to the metal bar through an existing hole, and was able to hide all of wires covered with wire wrap under the metal bar using only one zip tie and some electrical tape. A very clean install w/o any exposed wires, except the hot & ground wires plugged directly into each of the horns. No extra relay required and all you can see are the shiny labels on the horns through the grill, which looks pretty cool! Sounds great as well at 115db!
CactusJK is offline
Old 11-28-2007, 11:14 AM   #23 (permalink)
Banned
Member Number: 14075
Location: The Beautiful Pacific North West in Yakima, Washington
SwissArmySuv previously said: View Post
Enough about the horn, where did you get those fog light's ?
FJ CRUZER is offline
Old 11-28-2007, 12:08 PM   #24 (permalink)
MR. FJCZR's Avatar
Member Number: 9070
Send a message via AIM to MR. FJCZR
I just installed the second horn from Toyota and am very happy with the results. Just spliced in the original horns wire and attached to the second horn and bolted the horn right behind the grille and am very pleased.
Thanks Swiss!!!
Black Diamond / AT5 / Mickey Thompson Tires (D!ck CEPEK)- Radial F-C II 285/75/16 / Wheel Pros Helo Series HE 791 Maxx6 Black /
Magnaflow Gas Cat-Back Exhaust System / AIRAID Intake System / N-Fab Nerf Steps /
Daystar Comfort Ride Suspension Lift System / Tinted Windows / Aries Grille Guard
My Google Public Album
Trail Teams Training
TLCA #17717
MR. FJCZR is offline
Old 11-28-2007, 04:24 PM   #25 (permalink)
CactusJK's Avatar
Member Number: 1157
Starting to think PIAAs vice Hellas. Any last recommendations?
CactusJK is offline
Old 12-15-2007, 05:49 PM   #26 (permalink)
CactusJK's Avatar
Member Number: 1157
Is it best to run one ground wire between the two horn posts and then run a wire to ground from one of the horns?
CactusJK is offline
Old 12-15-2007, 07:07 PM   #27 (permalink)
GW193's Avatar
Member Number: 11341
I used the PIAAs, too. I also installed the stock horn in the secondary horn in the location in the passenger side at the rear of the engine bay. Three horns!!!
Gordon
"He's Cruisin' for a Bruisin'!"
Support Wheelers for the Wounded
2007 Titanium Metallic 4x4-Auto
TTORA #17699
GW193 is offline
Old 12-16-2007, 03:45 AM   #28 (permalink)
RomaBoy's Avatar
Member Number: 2866
CactusJK previously said: View Post
Not necessary, horns are bolted to steel body and that's the only ground you'll need.
RomaBoy is offline
Old 12-16-2007, 09:16 AM   #29 (permalink)
CactusJK's Avatar
Member Number: 1157
That sounds like an easy way to go since I am using the factory locations. Anyone else take this approach with PIAAs or others with a hot and a ground post?
RomaBoy previously said: View Post
CactusJK is offline
Old 01-08-2008, 08:50 PM   #30 (permalink)
Mark_JW's Avatar
Member Number: 16801
I just bought these Hellas but chose to spray them black before mounting so they are less obtrusive. Has anyone chosen to install Hellas in addition to the stock horn (3 horns ?)
Mark
07 Sun Fusion, 4x4, Auto
- Convenience Pkg, Upgrade Pkg 1, Side air bags, Roof rack, Black tire cover, Remote start (aftermarket), Tow hitch, Side visors, Dual Hella horns, RiteLite LED AAA interior lights.
Outstanding (Possibles)
- Stainless bull bar (Manik ?), Some color coding on bumper / grille etc , K&N filter and some fogs. H.I. bulbs, additional 12v outlets, Modding the mirrors to be turn signals
Mark_JW is offline
