Re: My FJ Stereo Install.....
Your fuse at the battery sould never be a higher rating than all the fuses combined at your amps. I.e. Your amps are rated at 25 amps each, you should have a main fuse rated at 50 amps. if you are using 60 amp fuses you are gluttin for trouble. In fact i might even run a 45 amp fuse to start with and see how that does. It is better to have to much protection than not enough. Having a lower amp rating fuse will do just that give you extra protection. If it blowes a few times then go up a few more amps but never exceed the max of your amplifiers combined. Chances are they will never need that kind of current to them and being a little under will do just fine. But if your friends make fun of you for using a small fuse then by all means go big. JK! Good Luck.
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
