Old 04-13-2007, 12:41 PM   #1 (permalink)
jnava121's Avatar
Member Number: 10780
Pop up GPS factory one
I saw the GPS systems for cheaper on Ebay like 745 versus 900 something at the dealer?
Are these a good deal? Would the dealer have to install that custom pop up compartment ?
jnava121 is offline
Old 04-13-2007, 01:03 PM   #2 (permalink)
JefFJ's Avatar
Member Number: 6651
Re: Pop up GPS factory one
I'm not sure what you saw on ebay (just the Quest 2 or the whole toyota install unit with Quest 2).
You can get the whole thing (mounting box and GPS) from the dealer/forum venders for just under $900.
One forum vender (I think trdsource) will let you buy just the mounting box for $400.
The Quest 2 (non-Toyota version) can be found for $500-$700 online.
One thing to keep in mind is that the Toyota Quest 2 unit is "special." Not only does it have Toyota dealerships pre-loaded, it comes w/ crippled firmware that eliminates the ability to turn off "safe mode." A post on this came up a few days ago and may be updated by now.
JefFJ is offline
Old 04-14-2007, 07:54 AM   #3 (permalink)
Steve_53's Avatar
Member Number: 9264
I bought mine on eBay (from a Toyota dealer), it was the "whole kit", p/n PT917-35070, which includes the "docking module", the wiring harness, and the GPS itself. I paid $739 including shipping.
Do be aware that the GPS unit has some additional limitations; in addition to not being able to disable Safe Mode, it will not accept any firmware updates that Garmin has available for the Quest2, including the latest DST fix.
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
Old 04-14-2007, 09:14 AM   #4 (permalink)
Truman's Avatar
Member Number: 1043
This new TomTom One might be a better option for you, I've been using it for a month now with outstanding results, positioned as you see here it's easy to hard wire directly to an unused fuse slot. The visor is home made. $299.00 everywhere
http://i69.photobucket.com/albums/i4...n/IMG_1697.jpg
Titanium - 4x4 - AT - UG#2 - TRD Exhaust
Skid Plate - Rock Rails - Roof Rack
Nitto Terra Grapplers 265/70/17
ProComp Alloys #7089-7883 17x8
EZ Lift 2" leveling kit
Ellis Precision Grab Handles
TomTom One GPS
NGK LFR6A-IX11 Iridium Spark Plugs
Piaa Extreme White Plus Headlight Bulbs #15224
Piaa 10 Watt incandescent Dome Bulbs
Mirror Light Upgrade (9LED amber)
Truman is offline
