Old 04-15-2007, 07:11 AM   #1 (permalink)
Corey's Avatar
Member Number: 2902
12v live power needed full time
The in cab fuse box has the extra plugs in it.
I plan on using one of these taps that was brought up in a thread somewhere.
Going to wire my ARB fridge to it.
Has anyone used the extra fuse slots, and if so, can you point me to one that is live all the time with the key off?
That is if there is even one there that is full time.
Thanks,
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, to much to list, see my website & buildup thread
YotaTech | My Website | My Rigs Build-Up | My Penthouse | Video Of My Penthouse | Camping Gear Reviews | Rehinging Your ARB/Engel Fridge
Corey is offline
Old 04-15-2007, 08:01 AM   #2 (permalink)
wesayso's Avatar
Member Number: 5111
Re: 12v live power needed full time
Easy to find with a VOM or a test light like this one on ebay. The pointed tip allows you to check a wire through the insulation. I've had a Snap-On brand test light for years, but this one is much cheaper and is all a shade tree mechanic would need.
eBay Motors: Innova PRO SERIES Test Light - Circuit Tester #3810 NR (item 260105982498 end time Apr-15-07 13:12:07 PDT)
Grok FJ
NON supporting member
But do not worship it,
For it shall pass.
H. L. Mencken
Wesayso's mod up
'77 FJ40
'89 4Runner
'90 4Runner
'89 4Runner #2
wesayso is offline
Old 04-15-2007, 08:38 AM   #3 (permalink)
gj07fjc's Avatar
Member Number: 2192
Corey previously said: View Post
Thanks,
Here's one that taps into the sub wire (live all time).
07 Black Diamond MT6, 'A'-PKG.
gj07fjc is offline
Old 09-17-2007, 06:20 AM   #4 (permalink)
N8RV's Avatar
Member Number: 13733
Send a message via AIM to N8RV
There was a quick mod outlined on YotaTech.com for the 4Runner where a small jumper is made and plugged into the circuit for the 12v power plug, making it live full-time. It was so simple that even I did it!
Is there a similar mod for the FJ?
Don McNamara
Elkhart, IN
'99 4Runner (LURCH)
'07 FJ (Colby)
N8RV is offline
Old 09-17-2007, 06:37 AM   #5 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Corey, I don't know if you want to go through the trouble of installing one of these, if your only going to use one fuse for live power. But here is a link to my 12 volt fuse block thread.
CLEAN 12v Fuse Block Accessory Install w/Pics
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is online now
Old 09-17-2007, 07:17 AM   #6 (permalink)
Corey's Avatar
Member Number: 2902
Guy's, this is an old thread from April.
I have since added 12v power to the rear.
Corey's FJ with a few mods!
That was to power this puppy.
N8RV, I remember that mod on YotaTech, many did it.
It is in the tech writeup section.
Full Time Power Outlets - 01 Tacoma - YotaTech Forums
Full Time Power Outlet Mod - 99 4Runner - YotaTech Forums
Corey
2007 FJ Cruiser
Corey is offline
Old 09-17-2007, 09:04 AM   #7 (permalink)
Raptor-nator
Member Number: 3913
My bad I should have looked at the date of the thread
Old 09-17-2007, 06:39 PM   #8 (permalink)
NCFJ's Avatar
Member Number: 8585
Shadow, I am of the same mind as you when it comes to electrical systems. I ran a Circuit Boss 7 circuit fuse block from Painless Wiring straight from the battery to the same place, although I did not make such a nice mounting plate. This fuse block has 4 switched circuits and 3 constant current circuits. It was $68 and came with everything I needed.
NCFJ is online now
Old 09-17-2007, 06:55 PM   #9 (permalink)
stnmikita's Avatar
Member Number: 4279
NCFJ previously said: View Post
NC,
Any pics of your set-up? I would like to do this mod and am curious about the best/most heavy-duty option for the fuse block.
Thanks!
If you can read this, thank a teacher.
If it's in English, thank a soldier.
stnmikita is offline
