This evening I changed the rear speakers in my FJ.
I have the FJammer with 8 speakers. These are the first speakers I ave changed everything else is stock.
After changing the driver's side I turned on the radio. everything was fine. I turned off the vehicle.
I changed the passenger's side. NO sound. None at all. Not out of any speaker.
The radio itself seems to be working. it lights up and shows it is reading the Cd, I tried changing to FM...no avail.
There are 2 fuses for the Radio. Neither are blown.
Still no sound from Radio.
Replaced the original speakers. No sound.
The new speakers are Rockford 4" - 4 ohm.
I do not know how this happened, but I apparently damaged the FJammer in changing the speakers. I realize there is a subtle difference in the ohm load the head unit would now see. Unfortunately I never had both rear speakers work, so I doubt that this overloaded the FJammer.
Still it does not work.
I realize I could probably take this to the dealer, but I feel that would be dishonest. I did this damage....somehow.
I guess I will have to spend some MORE money on new head unit/amp,etc.
Agree with RipsFJ, but I also ran into this problem.
I replaced mine with some Polk 4" db400 and used 1/4" nylon washers to give some space from the body panels and the magnet. I'm no electrician, but I think you might have a grounding issue?
I don't have the FJammer, just the regular CD/Tuner. I noticed when installing my aftermarket rear speakers that if 1 of them grounded, it would kill sound in all 8 speakers. Just to be safe, I wrapped the speaker connectors with e-tape. Sound returned when the connectors weren't touching the metal back there.
__________________ Rick C ~ ~ I aim to misbehave. 2007 GSJ15//Ti Ag//4WD AT All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount Bud Built trans skid/crossmember/gas skid Metal-Tech red sliders OME 886/895 springs & shocks Super Swamper 34" LTBs Warn 9.5xp/Masterpull line Demello rear bumper
