Old 04-20-2007, 06:55 PM   #1 (permalink)
RavenFJ's Avatar
Member Number: 8451
Power, speaker and interconnect routing
Looking at my rig (sans interior), it looks very possible to route wiring back at the side/roof area. Just looking for any opinions pos. or neg. regarding this route. In routing audio wiring, you want to isolate from oem wiring, also running power seperate from speaker/ interconnects, and I see this being ideal (no wiring in the way).
RavenFJ is offline
Old 04-20-2007, 08:22 PM   #2 (permalink)
Bang Bang's Avatar
Member Number: 3795
Re: Power, speaker and interconnect routing
ummmmm...yeah, sure...sounds great...
Pardon my ignorance but what the hell are you talking about? Do you mean would it be feasible to run your wiring through the headliner instead of under the flooring? If that is what you meant, you may want to search through some of the other posts on removing the headliner. You have to tear apart almost the entire interior of the rig to get it out. I have all mine run under the flooring and have not had any trouble. I have never worried about the factory wiring in any aftermarket instal I have done. I just make sure to not run my amp power / ground leads near my speaker wire.
Mike
Where do you park your ride? Check this out...GarageFreaks.com
Acquired 07/03/06 2WD SUN FUSION
Member of the Hurricane Cruisers and damn proud of it!!
Thanks to Nate and Randy for their fine craftsmanship!!
Bang Bang is offline
Old 04-20-2007, 08:28 PM   #3 (permalink)
RavenFJ's Avatar
Member Number: 8451
sans interior = my interior is out, that's why I was looking at this. Pics are in my gallery, click on member's name to access.
RavenFJ is offline
Old 04-20-2007, 08:41 PM   #4 (permalink)
Bang Bang's Avatar
Member Number: 3795
Well then, sure...go for it...it just sounds like a lot of trouble to me for very little benefit. Just my .02!!
Note to self: need to remember the word sans
Mike
Old 04-20-2007, 09:13 PM   #5 (permalink)
RavenFJ's Avatar
Member Number: 8451
Actually alot less trouble, nothing in the way. Yea, sans = none.
RavenFJ is offline
Old 04-20-2007, 09:27 PM   #6 (permalink)
Bang Bang's Avatar
Member Number: 3795
I guess because I always look at the cons to everything and try to trouble shoot before anything goes wrong is why I see little benefit. What happens if something does happen to the wiring and you have to get to it? Or you want to change out a part of your system and you have to change out wiring? In my life, if it can go wrong, it eventually will. So, I try to stick to the simple road. Makes life easier in the long run.
Mike
Old 05-02-2007, 10:10 AM   #7 (permalink)
RavenFJ's Avatar
Member Number: 8451
Anyone else have an opinion on this subject?
RavenFJ is offline
Old 05-02-2007, 10:54 AM   #8 (permalink)
Member Number: 3769
RavenFJ previously said: View Post
My opinion, since you asked, is that it's a mildly bad idea. If idea is to have better sound, it's very unlikely that you'd gain anything you can hear. There are many installers and people with very nice setups here, and as far as I know, none of them have ever posted "man, if only I hadn't run cable on the floor... !"
On the floor, the routing is clear and understood so you won't run into any unforseen gotchas. On the other, nobody (again, as far as I know) has run wire upstairs. So while it may look good to the eyeball, you may also run into some frustrating problems. Additionally, you will have to use considerably more cable to get the job done. More cable is potentially more interference on rougly the same level as you might avoid by not running it on the floor.
So I'd say the risk (small) outweighs the gain (virtually zero).
ChrisInSeattle is offline
Old 05-02-2007, 11:47 AM   #9 (permalink)
RavenFJ's Avatar
Member Number: 8451
I welcome all comments Chris. It's certainly not totally an issue of interference. As far as length, It's ~2.5ft to the roof or floor from the firewall penetration, and I'm seriously considering a roof mounted amp/preamp install ala northshorevoodoo(thanks for the idea Sean). Instead of running parallel to any OEM wiring, there's a whole lot of room away from OEM wiring upstairs, and should actually be an easier run. No screwing around with stuffing it under the floor mat, etc.
The rear seat area will have a molded fiberglass tub, with flat top even with the cargo floor, and will be my second choice for location of the amp and preamp if there is enough room (sketchy at this point) Either locations will be mechanically ventilated.
RavenFJ is offline
Old 05-02-2007, 03:45 PM   #10 (permalink)
Member Number: 3769
Well if you're going to mount amps in the ceiling, it's a no brainer. If you're mounting them on the floor, my guesstimate is that your run is about 4-5 feet longer. Between added length and running next to OEM wiring, it's about a wash (too close to 0 to notice either way).
My cable runs under the door sills, so it's clean. I have a little cable under the rear plastic to get connections to my under-seat amps.
Like my pappy used to say, "if you find a solution to a problem, stop there... before you cut your thumb off... (stupid kid)..."
