Derekls@mac.com previously said:
I have a roof rack light bar and some hella lights that I am going to hook up on friday
does anyone have any advice or anyting like that on installing these lights
the bar already has mounting spots for the light but what im needin help with is how to acutally hook the lighst up to make them work
thanks
derek
For the rear lights I went with this solution:
Roof rack wiring? Use the A - Pillar or drill a hole in the roof?
It was clean, easy, and works well.
For the front lights I drilled into the roof rack, then into the roof at the passengers side. I was able to easily snake the wires into the roof rack, over the headliner and down the A pillar with no problems or removal of the headliner. The trick is protecting the wires from scraping with wireloom or a rubber gromit and using plenty of black goo to be sure it seals well. So far, so good and it looks very clean.
