Old 04-26-2007, 07:06 PM   #1 (permalink)
fourx4ord's Avatar
Member Number: 5620
New System for The FJ
I just had all this installed
http://www.fjcruiserforums.com/galle...00&ppuser=5620
Sounds sweet
It does need a subwoofer
Any ideas on one that can mount under the drivers seat or the back door?
I do not want to give up cargo space
fourx4ord is offline
Old 04-26-2007, 07:14 PM   #2 (permalink)
Briman42487's Avatar
Member Number: 7204
Re: New System for The FJ
you wont be able to get anything under the drivers seat or back door. in the rear door you have a wiper motor in your way, and it is an acoustical nightmare. under the seat is only for a really custom fab job. you have to cut the floor, and essentially weld in a well for the enclosure to sit in, or make the enclosure, coat it with resin inside and out and bedliner outside, then really seal the area around the hole. that is only for extreme applications that are well funded. other options would be a, ehhh, pre-fab box to fit where the stock woofer goes.
Briman42487 is offline
Old 04-27-2007, 03:06 PM   #3 (permalink)
Nazar's Avatar
Member Number: 6383
fourx4ord previously said: View Post
Sounds sweet
I am not sure about the dimensions of that amp but, You may be able to fit the amp under pass seat if you take the heat duct out, ANd you can get one of our enclosures you will not have any issues with the cargo compartment since the FJ enclosures we make only take up the space that will not be utilized in most cases.
Home of Custom Fit Fiberglass Subwoofer Enclosures, We call them "MagicBox" http://www.fjcruiserforums.com/forum...icked-cas.html
NOW AVAILABLE FOR YOUR FJ CRUISER IN 1X12" or 2X10" Configurations.
JL AUDIO, FOCAL, KENWOOD, MEMPHIS, DYNAMAT, COMPUSTAR, CLIFFORD, AUDISON, ACCESSORIES PARTS AND MUCH MORE. Please call us with any needs for great service and unbeatable savings. 603-642-4222
Nazar is offline
Old 04-27-2007, 03:21 PM   #4 (permalink)
bartt's Avatar
Member Number: 1660
Actually with some careful fab you can install a sub on the rear door. I did it and it sounds great. You just have to be careful about the depth of the driver you use so it doesn't interfere with the wiper motor..
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline
Old 04-27-2007, 05:50 PM   #5 (permalink)
fourx4ord's Avatar
Member Number: 5620
bartt previously said: View Post
What sub did you use?
Any Pics?
Thanks
Old 04-27-2007, 05:51 PM   #6 (permalink)
fourx4ord's Avatar
Member Number: 5620
Nazar previously said: View Post
Amp is installed under the seat
Old 04-27-2007, 06:37 PM   #7 (permalink)
Nazar's Avatar
Member Number: 6383
Ahhh then you are ready for my enclosure... LOL
Nazar is offline
Old 05-04-2007, 04:47 PM   #8 (permalink)
swamp thing's Avatar
Member Number: 11015
That looks great. Do you have pics or details on how you did it? I'm thinking of something similar, and any help would be appreciated. Is that a 10" in the door?
swamp thing is offline
Old 05-04-2007, 05:14 PM   #9 (permalink)
fourx4ord's Avatar
Member Number: 5620
swamp thing previously said: View Post
I had it all professionally installed
With the LoJack and Viper Alarm/Remote Start I didn't want to mess with it
Plus I wouldn't want to be the one cutting the door panels up
Door woofers are 8"
I think they were 4" mids in the dash
I think 1: tweets in top of doors
Amp under passenger seat
I will take a few pics in a little bit and post them
Old 05-04-2007, 06:09 PM   #10 (permalink)
fourx4ord's Avatar
Member Number: 5620
