Re: FJammer-Sirius question
The head units were designed to work with XM "brains" and the Sirius module is a "converter" to convert the controls designed to work with XM to work with Sirius.
Problem is the only thing you can control is volume & channel chages plus toggle (using text button) between name of channel, name of artist or name of song title but it will only display 8 characters and doesn't scroll (ie: Allman Brothers Band is "Allman Br".
That being said, the dealer pulled the radio Saturday and wiggled the wires and it started working again. I have noticed the reception is not as good as in my other car due I presume to antenna placement (right at the lip of the top of the windshield, when generally the antenna's like to be surrounded by metal at least 5 " or so all the way around and my coaxial wire to the antenna may be crimped a little somewhere since they have to fish it around the winshield seal and up under the dash.
And by the way, the stock speakers pretty much do suck but are no worse than most mid priced vehicles stock speakers. A reasonable upgrade to just the door speakers would probably improve it a bit without going nuts replacing head units, amps, adding subwoofers & expensive x-overs is overkill unless that's real important to you
