Old 05-04-2007, 09:37 AM   #1 (permalink)
Slow35th's Avatar
Member Number: 9940
Firmware upgrade available for Garmin Quest 2
Last night I noticed that Garmin has released firmware version 3.00 for the Quest 2 units. Even though it has an April date it was only released in the last day or so because the latest version available last week was 2.90. The website states that this updates the unit for use on a Mac but often other unstated improvements are incorporated in firmware releases.
I don't know if it will work on the Toyota units because 2.90 would not but you might try. If it does there are a lot of people that would be very happy.
Edit: BTW, This update is only available by using the web updater.
Slow35th is offline
Old 05-04-2007, 10:45 AM   #2 (permalink)
Steve_53's Avatar
Member Number: 9264
Re: Firmware upgrade available for Quest 2
I'm running out to my FJ right now to grab the GPS, I'll post the results shortly.......
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
Old 05-04-2007, 11:15 AM   #3 (permalink)
Steve_53's Avatar
Member Number: 9264
"No updates were found for your Garmin device"
I'm getting really pissed!
Steve
Steve_53 is offline
Old 05-04-2007, 11:18 AM   #4 (permalink)
Slow35th's Avatar
Member Number: 9940
Steve_53 previously said: View Post
Sorry Man. I was hopefull this would help you out. Hack time. If you do decide to hack it, I have 2.90 which is no longer on the website since 3.00 is only available through the web updater.
Slow35th is offline
