Old 10-13-2007, 08:14 PM   #11 (permalink)
CommGuru's Avatar
Member Number: 13749
Re: Uniden CB Install - Pics
Steve,
I also have an old CB that wont fit in the center console, and was thinking of that place to install, just thinking of power and RF cable placement. I was not thinking of using the Bandi mount, put getting a mount that attaches the rack. This provides higher mount options and antennal angle adjustments (as needed). Good post thanks for the pics.
It has yet to be proven that intelligence has any survival value. Arthur C. Clarke
HELP CURE CANCER -
My fundraising page for battling blood cancers and running in the Marathon in Chicago.
______________________________________
'07 Titanium, 4X4 AT, Alloy Wheels, Upgrade #2.
OME 3" Heavy
CommGuru is offline
Old 10-13-2007, 08:37 PM   #12 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
nevadaesh previously said: View Post
Steve, a couple of questions. (I just did a PM but I have more questions) Do you have to take off the interior side mouldings to fish the coax? The power does not have to go to the battery?
Gary - -just sent you a reply to your PM.
No, I didn't have to remove the interior panels to fish the coax through, but I did pop a few corners of the plastic off their respective clips . . . just enough to squeeze my hand behind the panels to aid with the fishing. (A straighened-out old wire coat hanger has served me well for years as my "fishing rod.")
You could connect you CB directly to the battery, provided that there's an in-line fuse between the two. However, many find it easier to either tap into an existing fuse terminal with an Add-A-Circuit, or mount an auxillary fuse block to handle the aftermarket add-ons. That fuse block, in turn, can be connected to the battery (preferably via an in-line 50-75 amp automotive circuit breaker).
Or you could install a relay between the battery and the fuse block, so that it will be activated (and deactivated) with the FJ's ignition turned on or off.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 10-13-2007, 08:39 PM   #13 (permalink)
Member Number: 8627
CommGuru previously said: View Post
I was not thinking of using the Bandi mount, but getting a mount that attaches the rack. This provides higher mount options and antennal angle adjustments (as needed). Good post thanks for the pics.
You're welcome for the pics, CommGuru. Please let us see your rack-mounted antenna when you get it installed. Thanks.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 10-13-2007, 09:15 PM   #14 (permalink)
CommGuru's Avatar
I sure will, need to stop going to starsmucks and save money.....
HELP CURE CANCER -
OME 3" Heavy
CommGuru is offline
Old 10-14-2007, 08:48 AM   #15 (permalink)
estysalinas's Avatar
Member Number: 13250
I was orginally going to install my CB in the same place, but after mounting i realized that it prevented the rear seats from folding and laying flat! Doh!
2008 Titanium FJ with OF Package
*Bud Built Skid Plates
*Trail Gear Rock Rails
*Toytec 3" Custom lift
*Scuba Rear Diff breather mod
*Uniden PC78XL w/firestick 3ft
*285/75/16 Hankook Dynapro MTs
*ARB Roof Rack
*Soon: ARB Front Bumper
estysalinas is offline
Old 04-01-2008, 09:20 PM   #16 (permalink)
Member Number: 8627
Even after a year, I'm still pleased with my CB's location. However, the microphone was slightly difficult to use coming off of the rear-mounted CB and awkward to return it to its holder on the side of the radio itself.
So, I bought a 4-pin CB microphone plug and panel-mount jack from Radio Shack.
And, along with the appropriate 4-conductor cable, I created a microphone extension cable that connects to the CB's microphone jack and is panel-mounted to the right of the transmission to accept the microphone. (The cable is routed through the inside of the shift console.)
Now my CB mike can hang within easy reach and slipping it back into the holder is a breeze.
And, while I was at it, I finally got around to consolidating all of my after-market electrical accessories into a single fuse block.
12-Circuit "Switched" Fuse Block (Installation w/ pics)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 04-02-2008, 08:41 AM   #17 (permalink)
jamesart86's Avatar
Member Number: 17436
I'm going to have to wire my cb direct, I did an add-a-circuit and am getting feedback when I hit the brakes or roll down the windows. Anyone else getting this noise?
08' Sandstorm 6mt FJ blacked out with 3" OME lift, BFG m/t KM2's, All Pro front bumper and skid, smittybilt winch, homemade sliders, homemade skids, trail damaged rear bumper.
07' Kawasaki Ninja zx-6r
73' VW Thing
jamesart86 is offline
Old 04-02-2008, 08:55 AM   #18 (permalink)
Member Number: 8627
jamesart86 previously said: View Post
No, even before I went the direct fuse block route, I never got any interference with the Add-A-Circuit.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 04-02-2008, 10:12 AM   #19 (permalink)
doublejfj's Avatar
Member Number: 17287
Fantastic, good work!
At one time, I was working on something similar for my other car, but the radioshack here only had the female, not the male. I'll have to re-visit this now and see if they've got them...
J+J+FJ - '08 Titanium MT6 - Not stock, pinstriped paintjob.
Finally, our integrated USB chargers are here!
IP68 cable glands for roof rack wiring!
Tell us why you deserve a FREE Quad USB charger
doublejfj is offline
Old 04-02-2008, 10:22 AM   #20 (permalink)
JoeUser's Avatar
Member Number: 15334
Nice install (particularly the remote mic connector). I have the PC78XLT, which is basically the same radio, but with a built-in SWR meter (great radio).
I located mine on the left side of the console, foward of the seat. The mic holder is toward the driver, so it is comfortably within reach. Plus the controls are easily accessible, too.
Only downside is that my right leg rests against the bottom of the radio, but it's not uncomfortable at all (after taking a few days to get used to having something there).
There's just not a lot of places to mount a full-sized radio, but I really like your location. Only I fold the seat down too often...
Dennis' Titanium:
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT & K40 hatch-mounted whip; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack
JoeUser is offline
