Old 07-06-2007, 02:11 PM   #41 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Re: CLEAN 12v Fuse Block Accessory Install w/Pics
I noticed that the thread has Five Stars now, I'm glad it's helping others out. I wonder if it should be made a “Sticky” ?. I wonder what the MOD’s think..Humm…
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
TLCA Member : #18084
Honorary AZFJ Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 09-17-2007, 07:34 AM   #42 (permalink)
N8RV's Avatar
Member Number: 13733
Send a message via AIM to N8RV
Just out of curiosity, Mike, why did you run your ground from the fender rather than just a short jumper to the bolt where you mounted the fuse block? I'm assuming it's grounded to the frame as well.
Any reason not to do that and save a long wire run?
Don McNamara
Elkhart, IN
'99 4Runner (LURCH)
'07 FJ (Colby)
N8RV is offline
Old 09-17-2007, 09:06 AM   #43 (permalink)
Raptor-nator
Member Number: 3913
N8RV previously said: View Post
You can, I just wanted everything that I was running kind of up-front so it's easier to troubleshoot if something happens
Old 09-17-2007, 12:06 PM   #44 (permalink)
TIT-CRUISER's Avatar
Member Number: 9095
I was thinking the same thing.
Shadow,
Another great write up!
TITanium Metallic FJ Cruiser
TIT-CRUISER is online now
Old 09-17-2007, 12:25 PM   #45 (permalink)
Member Number: 12345
Weird, I ended up with the same fuse block but i installed it on an aluminum bracket adjacent to the under hood fuseblock, drivers side. I made the bracket out of angle aluminum and riveted it together, painted it flat lack and used oem bolts to install it.
Discojon is offline
Old 09-19-2007, 10:28 PM   #46 (permalink)
FJoel's Avatar
Member Number: 4197
Cool. Thanks for the info! Gotta do this ASAP!
But I see a 09 Amp fuse, I thought you said 60 AMP?
FJoel is offline
Old 09-19-2007, 10:34 PM   #47 (permalink)
TCao's Avatar
Member Number: 940
shadow-warrior previously said: View Post
I would want this thread stickied so I can find it faster. Thanks.
It's good practice to run ground wires to the same point to prevent ground loops which could cause interference with other electronic devices such as Ham radio or CB or stereo.
2007 Ti FJC
TCao is offline
Old 09-19-2007, 10:42 PM   #48 (permalink)
Chatsworth 818 FJ's Avatar
Member Number: 1770
Good write up!! Im not even thinking of doing it, but still read the post. It might have changed my mind, what a salesman if you ever want a job in sales PM me shadow.
Chatsworth 818 FJ is offline
Old 09-20-2007, 01:28 PM   #49 (permalink)
PlainRed RR's Avatar
Member Number: 13267
very cool, i really don't like having to tap the fuse box for acc. this is on my to-do list.
More addicting than meth....not that I know...
http://4x4country.net/register.php?REF=8933
PlainRed RR is offline
Old 10-12-2007, 05:45 PM   #50 (permalink)
iCruiser's Avatar
Member Number: 479
MelloFJYellow previously said: View Post
Shadow, I have a question for you about your Fuse block. I plan on running a total of 5 pairs of AUX lights on my FJ. I already have a dual-battery setup ready to be installed, and I would like to know if you think I could (or, better yet, should) install one of these additional Fuse blocks, as well.
If he's planning to run 5 pairs of lights, what size wire should one run from the batt to the block? will 10 guage be able to handle that or should one goto perhaps 6 or 4 guage?
Is there a chart to tell you the recommended wire size to load?
T
iCruiser is offline
