Old 11-24-2007, 11:35 AM   #61 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Re: CLEAN 12v Fuse Block Accessory Install w/Pics
When do I leave
Damn Todd your rig looks awesome buddy on the inside too, wow you have done a great job
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
TLCA Member : #18084
Honorary AZFJ Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 12-02-2007, 11:40 PM   #62 (permalink)
Aslan's Avatar
Member Number: 7376
Thanks to your write up, I just finished the same wiring job. I located my blue sea fuse block in the same location. (My bracket didn't turn out quite as nice as yours, but I'm happy with it.)
The only things I did slightly different from your install were:
1) I added two 1/4" loops (used to secure cables against walls) to either side of my bracket at the top. These are used to help in routing wires.
2) I put heat shrink tubing on all connections
3) put some RTV on the rubber gasket where the wiring was run from the engine compartment into the cabin
4) I have not yet added a fuse to the wiring supplying power to the new fuse block.
Your excellent write up was my reference and made the task 1000% easier for me. Thank you!
Black Cherry "WartHog", DR suspension (front and rear), TC UCA's, AFE CAI, ARB full length roof rack, Toyota Brush Guard & lights, Scuba Driver Mod, Baja 540c, body mount chop, Moto Metal 0951B wheels, Nitto Terra Grappler 285/70/17's
Aslan is online now
Old 12-06-2007, 09:29 PM   #63 (permalink)
layonnn's Avatar
Member Number: 10006
Can you run auxillary lights through this fuse block???
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 12-06-2007, 09:42 PM   #64 (permalink)
Raptor-nator
Member Number: 3913
Aslan previously said: View Post
Thanks
It depends on the type of lighting requirements, I am running IPF's they require you to go straight to the Battery for the power, they also have their own built in fuse block in the harness. If you plan on running fog's, or that type of lighting, that is how I would run it, right to this fuse block. I hope this helps.
Old 01-14-2008, 03:42 PM   #65 (permalink)
briwilbarn's Avatar
Member Number: 16824
so wait...how exactly do you get the fuseblock to activate on ignition and deactivate off ignition? I need some pictures or more detailed instructions...
And what accessories did you run to your fuseblock shadow?
And what exact fuseblock is it? this one: Amazon.com: BLUE SEA SYSTEMS ST BLADE FUSE BLOCK WITH COVERDesc: 6 Circuit with Negative Bus: ?
stucks
BREEZY
Silver '07 FJCruiser A/T
VSC Cancel Switch, Pioneer AVIC Z2, MTX amp/subwoofer, Cobra 29 CB w/ PA, Bandi Mount, RC 6inch lift, Enduro KMC beadlocks, Mickey Thompson 35" Baja Claws
briwilbarn is offline
Old 01-18-2008, 06:28 AM   #66 (permalink)
NCFJ's Avatar
Member Number: 8585
To activate the fuse block with ignition you tap into a circuit in the main fuse block that is on with ign, off when key is off. That wire runs to a relay and that relay turns on the circuits in the fuse block.
I used the Painless Wiring Circuit Boss 7 circuit fuse block because it has 4 switched circuits and 3 constant.
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is online now
Old 01-22-2008, 02:00 PM   #67 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
NCFJ previously said: View Post
Stan, what would be a good high amperage 12V relay that's typically available at auto parts stores?? I'm getting ready to install Blue Sea's 12 fuse slot module and make all 12 positions ignition off/on switchable.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 01-22-2008, 02:25 PM   #68 (permalink)
NCFJ's Avatar
Member Number: 8585
Steve,
The Painless fuse block I used came with a 30 AMP relay attatched. That was to control 4 circuits. I am thinking that if you want to control 12 circuits with one relay you would at least want to double that to 60 Amps. I know that Advanced Auto and Auto Zone both sell the 30 AMP relays but not sure on anything bigger than that. Something that large may be a special order.
NCFJ is online now
Old 01-23-2008, 09:40 AM   #69 (permalink)
Member Number: 8627
I am thinking that if you want to control 12 circuits with one relay you would at least want to double that to 60 Amps. Something that large may be a special order.
Yep, that's what I was thinking. Perhaps someplace that sells commercial truck parts/supplies.
Thanks, Stan.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 01-23-2008, 11:26 AM   #70 (permalink)
NCFJ's Avatar
Member Number: 8585
Thanks, Stan.
Steve, I am not familiar with the fuse block you are using, but would it be possible to split the feed into 2 6 circuit units and then use two seperate 30 AMP supplies? THis would also allow you to use 2 smaller gauge supply lines rather than one large gauge wire to supply all 12 circuits. Just a thought.
Stan
NCFJ is online now
